Description Resource In Folder Location
** [ext_flash.flash] Error 5 hello_world_0
** [rebuild] Error 2 hello_world_0
34 PM - (??) elf2flash: Error generating Flash file, exiting[Dec 13, 2004 11] hello_world_0 line 58
34 PM - (??) elf2flash: Error reading boot copier[Dec 13, 2004 11] hello_world_0 line 58
34 PM - (??) elf2flash: Read error: File not found: /boot_loader_cfi.srec[Dec 13, 2004 11] hello_world_0 line 58
make -s all
Post-processing to create ext_flash.flash
C:/quartus/sopc_builder/bin/find_sopc_component_dir: not found
WARNING: Default charset GBK not supported, using ISO-8859-1 instead
make: *** [ext_flash.flash] Error 5
Dec 14, 2004 12:05:20 AM - (??) elf2flash: Read error: File not found: /boot_loader_cfi.srec
Dec 14, 2004 12:05:21 AM - (??) elf2flash: Error reading boot copier
Dec 14, 2004 12:05:21 AM - (??) elf2flash: Error generating Flash file, exiting
Build completed
*** [ext_flash.flash] Error 5 hello_world_2
Default charset GBK not supported, using ISO-8859-1 instead,,,,,怎么回事??那地方配置不对。选项默认ISO-8859-1。我指定后仍然这样错误。
请遇到此问题的大虾多多指点。 |
