编译不通过,看不懂 library ieee; use ieee.std_logic_1164.all; entity hdb3 is port(codein:in std_logic; clk: in std_logic; clr: in std_logic; codeout ut std_logic_vector(1 downto 0)); end hdb3; architecture behave of hdb3 is signal cnt0:integer:=0; signal flag0:integer range 1 downto 0:=0; signal flag1:integer range 1 downto 0:=0; signal flag2:integer range 1 downto 0:=1; signal flag3:integer range 1 downto 0:=0; signal firstv:integer range 1 downto 0:=0; signal codeoutv:std_logic_vector(2 downto 0); signal s0:std_logic_vector(4 downto 0):="00000"; signal codeoutb:std_logic_vector(2 downto 0); signal s1:std_logic_vector(4 downto 0):="00000"; signal clkb:std_logic; signal clkv:std_logic; signal clkout:std_logic; signal s2:std_logic_vector(4 downto 0):="00000"; signal s3:std_logic_vector(2 downto 0); component dff port(d : in std_logic; clk : in std_logic; q : out std_logic); end component; ---------------------------------------------------------插V begin --vclk:clkv<=clk after 10 ns; add_v:process(clk,clr) begin if clk'event and clk='1' then if clr='1' then codeoutv<="000"; cnt0<=0; else case codein is when '1'=> cnt0<=0; if(flag0=0) then codeoutv<="110"; flag0<=1; else codeoutv<="010"; flag0<=0; end if; when '0'=> if cnt0=3 then if firstv=0 then if flag0=0 then codeoutv<="011"; flag1<=0; else codeoutv<="111"; flag1<=1; end if; firstv<=1; else if flag1=0 then codeoutv<="111"; flag1<=1; flag0<=1; else codeoutv<="011"; flag1<=0; flag0<=0; end if; end if; cnt0<=0; else cnt0<=0; else cnt0<=cnt0+1; codeoutv<="000"; end if; when others=> codeoutv<="000"; cnt0<=cnt0; end case; end if; end if; end process add_v; s0(0)<=codeoutv(0); s1(0)<=codeoutv(1); s2(0)<=codeoutv(2); ds21:dff port map(s2(0),clk,s2(1)); ds11:dff port map(s1(0),clk,s1(1)); ds01:dff port map(s0(0),clk,s0(1)); ds22:dff port map(s2(1),clk,s2(2)); ds12:dff port map(s1(1),clk,s1(2)); ds02:dff port map(s0(1),clk,s0(2)); ds23:dff port map(s2(2),clk,s2(3)); ds13:dff port map(s1(2),clk,s1(3)); ds03:dff port map(s0(2),clk,s0(3)); --------------------------------插B bclk:clkb<= not clk; add_b:process(clkb) begin if clkb'event and clkb='1' then case codeoutv is when "110"=> flag3<=1; s2(4)<=s2(3); s1(4)<=s1(3); s0(4)<=s0(3); when "010"=> flag3<=0; s2(4)<=s2(3); s1(4)<=s1(3); s0(4)<=s0(3); when "111"=> if flag3=0 then s2(4)<='1'; s1(4)<='0'; s0(4)<='1'; flag3<=1; else s2(4)<=s2(3); s1(4)<=s1(3); s0(4)<=s0(3); end if; flag2<=1; when"011"=> if flag3=0 then s2(4)<=s2(3); s1(4)<=s1(3); s0(4)<=s0(3); else s2(4)<='0'; s1(4)<='0'; s0(4)<='1'; flag3<=0; end if; flag2<=0; when others=> s2(4)<=s2(3); s1(4)<=s1(3); s0(4)<=s0(3); end case; codeoutb<=s2(4)&s1(4)&s0(4); end if; end process add_b; -----------------------------------------输出 outclk:clkout<=clk after 5 ns; output:process(clkout) begin if clkout'event and clkout='1' then if codeoutb="000" then codeout<="00"; elsif codeoutb="001" or codeoutb="010" or codeoutb="011" then codeout<="01"; else codeoutb="10"; end if; end if; end process output; end behave; |
