用IP core Generator 生成了一个512点fft核,可在使用时老是通不过,出现这样的错误,不知该怎么解决呢?? Started : "Create Schematic Symbol". Compiling vhdl file "F:/RecentWorks/Xfft_useIP/fft_system/fft_system/../FFTcore/FFTcore.vhd" in Library work. ERROR:HDLParsers:3014 - "F:/RecentWorks/Xfft_useIP/fft_system/fft_system/../FFTcore/FFTcore.vhd" Line 39. Library unit VPKG is not available in library UNISIM. vhdtdtfi eclaration (Module FFTcore) not found. tdtfi(vhdl) completed with errors. Process "Create Schematic Symbol" completed successfully |
