我的CMD文件: -STACK 40 MEMORY { PAGE 0: /*程序空间*/
VECS: origin = 0000h , length = 0040h /*中断向量存储空间*/ PVECS: origin = 0044h , length = 0100h /*外围中断向量*/ PROG: origin = 0150h , length = 7EAFh /*片内FLASH存储空间,以上为32K字片内Flash(0000h~8000h)*/ SARAM_P: origin = 8000h , length = 0800h /*程序空间上的2K字SARAM*/ EX1_PM: origin = 8800h , length = 7600h /*外部程序存储空间*/ B0_PM: origin = 0FF00h, length = 0100h /*若CNF=1为片上DARAM,否则为外部*/ /*B0=0FF00h~0FFFFh*/
PAGE 1: /*数据空间*/
MMRS: origin = 0000h , length = 0060h /*MMRS,内存映射寄存区和保留地址*/ BLK_B2: origin = 0060h , length = 0020h /*DARAM B2 块*/ BLK_B0: origin = 0200h , length = 0100h /*DARAM B0 块,若CNF=0,则分配为片内DARAM*/ BLK_B1: origin = 0300h , length = 0100h /*DARAM B1 块*/
/*若正确配置SCSR2寄存器,则此为数据空间中2K的数据SARAM区*/ SARAM_D: origin = 0800h , length = 0800h /*片内2K的数据SARAM*/ PERIPH: origin = 7000h , length = 1000h /*片内外设寄存器空间*/ EX2_DM: origin = 8000h , length = 8000h /*片外数据RAM*/
PAGE 2: /*I/O存储空间*/
IO_EX: origin = 0000h , length = 0FFF0h /*外部I/O映射空间*/ IO_IN: origin = 0FFF0h, length = 000Fh /*片内I/O映射空间*/ }
SECTIONS { .reset: {} > VECS PAGE 0 /*复位中断向量表*/ .vectors: {} > VECS PAGE 0 /*中断向量表*/ .pvecs: {} > PVECS PAGE 0 /*外围模块中断向量表*/ .text: {} > PROG PAGE 0 /*程序段*/ .cinit {} > PROG PAGE 0 .switch {} > PROG PAGE 0 .const {} > PROG PAGE 0
.data: {} > BLK_B1 PAGE 1 /*数据段*/ .bss: {} > SARAM_D PAGE 1 .stack {} > SARAM_D PAGE 1 /*堆栈--40个单元*/ } 但在运行时却出现如下错误: >> cannot allocate .vectors in VECS (page 0) >> cannot allocate .pvecs in PVECS (page 0) >> errors in input - ./Debug/PPID.out not built
Build Complete, 3 Errors, 0 Warnings, 0 Remarks. 请高手指点一下 谢谢! |
