library ieee; use ieee.std_logic_1164.all; entity two is port(n:in std_logic_vector(3 downto 0); f ut std_logic ); end two; architecture two_arch of two is begin process(n) begin with n select f<= '1' when "0001", '0' when others; end process; end two_arch; 这样的小程序,报错1:Error (10500): VHDL syntax error at two.vhd(12) near text "with"; expecting "end", or "(", or an identifier ("with" is a reserved keyword), or a sequential statment 报错2:Error (10500): VHDL syntax error at two.vhd(13) near text "when"; expecting ";" 真是不明白啊,不放在process里就好好的,放进process就有这样的错, 请高手指点啊!! 谢谢 |
