S12XDP512的AD转换结果不正确
S12XDP512的AD转换结果不正确
那位帮我看一下ATD转换的结果怎么不对啊?谢谢!!
#include <hidef.h> /* common defines and macros */
#include <mc9s12xdp512.h> /* derivative information */
#pragma LINK_INFO DERIVATIVE "mc9s12xdp512"
void delay_100us(void);
unsigned char jishu;
unsigned char resultr;
unsigned char result;
void delay_ms(int i); //USE the ATD1 converter
void main(void)
ATD1CTL0=0x0A; //WRAP Around to AN0
ATD1CTL1=0x00; // None External Trigger Source Select
ATD1CTL2=0xA0; // disabled ATD Sequence Complete interrupt requests, Enable external trigger,Ring Edge External Trigger
ATD1CTL3=0x0A; //One Conversion Sequence Length,
ATD1CTL4=0xA0; //8 bit resolution
delay_100us() ;
PORTA = 0xFF;
PORTB = 0x00;
PORTC = 0x00;
PORTD = 0x00;
DDRA = 0xFF;
DDRB = 0xFF;
DDRC = 0xFF;
DDRD = 0xFF;
ATD1CTL5=0x0A; // Left justified 8 bit data in the result registers, Analog Input Channel Select AN10
delay_ms(150);
PORTB_PB0=ATD1STAT0_SCF;
PORTB_PB2=ATD1STAT1_CCF0;
while(!ATD1STAT0_SCF)
PORTC=((0x07&ATD1DR0H)<<2);
PORTD=(0x1F&(ATD1DR0H>>3));
if(ATD1STAT0_SCF)
ATD1STAT0_SCF=1;
EnableInterrupts;
for(;;) {} /* wait forever */
/* please make sure that you never leave this function */
int i;
for(i=0;i<50;i++)
asm("nop");
void delay_ms (int i)
unsigned char j;
for(j=0;j<i;j++)
delay_100us();
