要用这个完成毕业设计,很多问题不知道怎么解决。希望赐教! *** Fatal Error: Module: quartus_map.exe Exception: Access Violation 0x3A35 : CDB_SGATE_COMB::CDB_SGATE_COMB + 0x17B (db_cdb_sgate) 0x3AFE : CDB_SGATE_COMB::CDB_SGATE_COMB + 0x244 (db_cdb_sgate) 0x3B15 : CDB_SGATE_COMB::sort_inputs + 0x11 (db_cdb_sgate) 0x1D490 : CDB_SGATE_NETLIST::sweep + 0x3B5 (db_cdb_sgate) 0x61F14 : opt_sea_of_mux + 0x3FF4C (SYNTH_OPT) 0x9F847 : SMP_ROOT: perator= + 0x273E (SYNTH_OPT) 0xA0DA9 : SMP_ROOT: perator= + 0x3CA0 (SYNTH_OPT) 0x9E2A0 : SMP_ROOT: perator= + 0x1197 (SYNTH_OPT) 0x1FDB : RTL_ROOT::process_netlist_scripted + 0x34E (SYNTH_OPT) 0x2429 : RTL_ROOT::process_sgate_netlist + 0x2BE (SYNTH_OPT) 0x6F54C : sgn_start + 0x6DA0D (synth_sgn) 0x6FD7A : sgn_start + 0x6E23B (synth_sgn) 0x29821 : sgn_start + 0x27CE2 (synth_sgn) 0x2ABD6 : sgn_start + 0x29097 (synth_sgn) 0x2AE3A : sgn_start + 0x292FB (synth_sgn) 0x1112 : DllSgnStart + 0x112 (synth_sgn) 0x1A9D : DllSgnStart + 0xA9D (synth_sgn) 0x1B6B : sgn_start + 0x2C (synth_sgn) 0x2E4F : (quartus_map) 0xB4A9 : (quartus_map) End-trace
刚装的系统,这又是个什么问题啊? |
