为连接七个模块写了一个顶层文件,编译出来有8个missing source的错误,单独的模块编译仿真都没有错误,符合各项功能,请高手指点,以下是顶层文件程序 LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; ENTITY CZC IS PORT ( SELIN:IN STD_LOGIC_VECTOR(2 DOWNTO 0); STARTIN,SDBZIN,WCLKIN,SCLKIN:IN STD_LOGIC;
DATAO:OUT STD_LOGIC_VECTOR(7 DOWNTO 0); LCBZO,DDBZO,XDBZO:OUT STD_LOGIC ); END CZC; ARCHITECTURE MODELSTRU OF CZC IS COMPONENT FPQ IS PORT(SCLK:IN STD_LOGIC; CLK1HZ:OUT STD_LOGIC); END COMPONENT FPQ ; COMPONENT DDPB IS PORT(START,WCLK:IN STD_LOGIC; CLK1HZ:IN STD_LOGIC; DDBZ:OUT STD_LOGIC); END COMPONENT DDPB; COMPONENT LCJS IS PORT(START,DDBZ,WCLK:IN STD_LOGIC; XSLC:OUT STD_LOGIC_VECTOR(15 DOWNTO 0); LCBZ,JFBZ:OUT STD_LOGIC); END COMPONENT LCJS ; COMPONENT LCJF IS GENERIC(SD1:INTEGER:=140; SD2:INTEGER:=180); PORT(LCBZ,JFBZ,START,DDBZ,SDBZ:IN STD_LOGIC; LCFY:OUT STD_LOGIC_VECTOR(15 DOWNTO 0)); END COMPONENT LCJF ; COMPONENT DDJS IS PORT(START,DDBZ:IN STD_LOGIC; CLK1HZ:IN STD_LOGIC; DDSJ:OUT STD_LOGIC_VECTOR(15 DOWNTO 0); XDBZ:OUT STD_LOGIC); END COMPONENT DDJS; COMPONENT DDJF IS GENERIC(WDJ1:INTEGER:=20; WDJ2:INTEGER:=33); PORT(START,XDBZ,DDBZ,CLK1HZ:IN STD_LOGIC; DDFY:OUT STD_LOGIC_VECTOR(15 DOWNTO 0)); END COMPONENT DDJF; COMPONENT SCXZ IS PORT(SEL:IN STD_LOGIC_VECTOR(2 DOWNTO 0); XSLC:IN STD_LOGIC_VECTOR(15 DOWNTO 0); LCFY:IN STD_LOGIC_VECTOR(15 DOWNTO 0); DDSJ:IN STD_LOGIC_VECTOR(15 DOWNTO 0); DDFY:IN STD_LOGIC_VECTOR(15 DOWNTO 0); DATA:OUT STD_LOGIC_VECTOR(7 DOWNTO 0)); END COMPONENT SCXZ; SIGNAL CL,DD,LCB,JF,XD,ST:STD_LOGIC; SIGNAL XSL,LCF,DDS,DDF:STD_LOGIC_VECTOR(15 DOWNTO 0);
BEGIN U1:FPQ PORT MAP(SCLK=>SCLKIN,CLK1HZ=>CL); U2 DPB PORT MAP(WCLK=>WCLKIN,START=>STARTIN,CLK1HZ=>CL,DDBZ=>DDBZO); U3 CJS PORT MAP(WCLK=>WCLKIN,START=>STARTIN,DDBZ=>DD,XSLC=>XSL,LCBZ=>LCBZO,JFBZ=>JF); U4 CJF PORT MAP(LCBZ=>LCB,JFBZ=>JF,START=>STARTIN,DDBZ=>DD,SDBZ=>SDBZIN,LCFY=>LCF); U5 DJS PORT MAP(START=>STARTIN,DDBZ=>DD,CLK1HZ=>CL,DDSJ=>DDS,XDBZ=>XDBZO); U6 DJF PORT MAP(START=>STARTIN,XDBZ=>XD,DDBZ=>DD,CLK1HZ=>CL,DDFY=>DDF); U7:SCXZ PORT MAP(SEL=>SELIN,XSLC=>XSL,LCFY=>LCF,DDSJ=>DDS,DDFY=>DDF,DATA=>DATAO); END ARCHITECTURE MODELSTRU; |
