HOLTEK新推出HT46RS03/HT46RS03P八位微控制器
HOLTEK半导体新推出内建整合多级放大器(OPA)、比较器(CMP)及稳压器(LDO)的微控制器HT46RS03、HT46RS03P。具有ROM为2k*15、RAM为128 bytes、I/O最多为16埠。除此之外,内建三个OPA及一个CMP组件,输入Offset可以透过软件调整的方式调整至?mV;内建一个8 bit及一个16 Bit Timer;提供Crystal 或ERC (External R.C.)的振荡电路,系统频率最高可达16MHz,其中ERC振荡电路经内部校正,在全工作电压及温度范围,振荡频率误差小于10%以内。HT46RS03P更内建一个5V稳压器,其输入电压可达24V,可提供系统稳定电源。其高度整合性架构,提供使用者一个具有优异性价比的解决方案。
加油!!顶贴!!!回帖!!!
Getting into the game Warrior at maximum tilt is hard to aion kinah do and survive through. World of Warcraft PvP guide will give you some tips to maximum the buy aion kinah strength of your Warrior and eliminate all of the weaknesses in PvP. Today we''re mainly cheap aion kinah focusing on Arms spec. As a leading and competitive wow gold store, customers all over the world can aion kinah for sale at wowgoldsbuy.com at a very low price. We have large and full wow gold in stock.
With the game released, the Arms Warrior has gone through a few changes. They aion kinah fast delivery were very powerful in the early stages of the game and then they were nerfed but now they''re back! You''re success aion kinah instant delivery as an Arms Warrior is going to rely on two abilities: Recklessness and Bladestorm. With these aion gold instant delivery two abilities, it is true that you have the ability to kill anyone. Blizzard aion gold fast delivery has given Warriors a unique power in that they can kill somebody every time Recklessness is up, no matter what. If you aren''t killing people with Recklessness, we''d say that you need to go gear up. |
- 来自
- 北京市
支持一下!有应用的产品方案介绍吗? |
