提供CPU/H264_MPEG4/USB/PCIe/SATA/3D/2D/DDR2/DDR3/24bit DSP/PHY等常用IP cores
-8bit 1T/2T/4T/12T MCU
8bit RISC CPU
Turbo 186
V6502
V8086
16bit MCU
32bit RISC CPU (MIPS/ARC/ARM)
IBM PowerPC405
IBM PowerPC440
IBM PowerPC460
IBM PowerPCPLB
Audio Echo Processor
16/24 audio DSP Core
16bit audio echo DSP core
16bit audio DAC (Digital design parts)
- Interface IP:
Usb1.0 Host/Device/Hub
Usb1.0 Low speed/Full speed PHY
Usb2.0 Host/Device/OTG controller
USB2.0 HS/OTG PHY @180nm/130nm/90nm/65nm (TSMC/SMIC/IBM/Charted process)
USB2.0 mobile nanoPHY @130nm/90nm/65nm (TSMC/SMIC/IBM/Charted process)
Wireless USB controller/wirless usb driver
PCI/PCI-X
PCI-Express endpoint/rootmode/swtich brige controller
PCI-Express PHY @130nm/90nm/65nm (TSMC/SMIC process)
IEEE1394 Controller
Ethernet 10/100/1000 Controller
Ethernet 10G MAC controller & PHY
IDE controoler
SATA host/device Controller
SATA PHY @130nm/90nm/65nm (TSMC/SMIC process)
Media Local BUS IP
SD_MMC host controller IP
LCD controller
MemoryStick Host controller
Smart card reader
AMBA2.0/3.0 IP
AMBA Interface IP
DDR2/DDR3 memory controller
DDR2/DDR memory controller
DDR3/DDR2 SDRAM PHY
DDR2/DDR2 SDRAM PHY
Mobile Storage controller (include SDIO/CEVA/MMC host controller)
SDIO device controller
WLAN AFE IP
TSMC PLL
Arasan Nand Flash controller/SDIO device controller
CMOS Sensor Interface IP
SPDIF Interface IP
- JPEG Encoder/Decoder/Codec
Motion-JPEG
MPEG2 Decoder
H264/MPEG4 codec
H264/MPEG4 decoder
H264/MPEG4 encoder
H264/MPEG4 HD codec
MPEG4 encoder
2D graphics core
3D graphics core for PDA & audio
3D graphics core for wirless products
TV encoder
另外还提供各种各样得synopsys & cadence & mentor & magma
等ASIC设计EDA平台(windows & linux & Solaris版本),有需要
可以email联系详细谈。
Email: soft_cores@163.com
