目前我在uclinux 2.6 上面编译我的应用程序,可是遇到了一个头文件的问题,感觉上是uclibc的问题,因为我比较了一下uclibc.org所提供的uclibc的header files,还是有很大的不同的。不知道大家们是不是也曾经遇到过。
The include directory is
"C:/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_0.1.0/include/".
In the file , I got the "undefined
error message" for the symbol "__le64", but it was defined in
. But unfortunately, only if we do not define
"__KERNEL_STRICT_NAMES", "__le64" will be defined as expected. And the
"__KERNEL_STRICT_NAMES" is defined in , since the
"_LOOSE_KERNEL_NAMES" is not defined.
多谢大家指点了。 |
