我现在搞一个项目碰到一些问题,望大家能帮我一下 我现在有MC9S08QE128作开发时,程序量已超过60K时用软件"make"的时候就会提示"out of allocation space in segment ROM at address 0x6734 "这样的错误,请问在.prm里要怎么样修改才可以解决此问题? 我现在的.prm文件如下: NAMES END /* CodeWarrior will pass all the needed files to the linker by command line. But here you may add your own files too. */ SEGMENTS /* Here all RAM/ROM areas of the device are listed. Used in PLACEMENT below. */ Z_RAM = READ_WRITE 0x0080 TO 0x00FF; RAM = READ_WRITE 0x0100 TO 0x17FF; RAM1 = READ_WRITE 0x1880 TO 0x207F; /* unbanked FLASH ROM */ ROM = READ_ONLY 0x2080 TO 0x7FFF; ///ROM = READ_ONLY 0x2080 TO 0xEFFF; ///ROM1 = READ_ONLY 0x13000 TO 0x1FFAD; ROM1 = READ_ONLY 0xC000 TO 0xFFAD; /* INTVECTS = READ_ONLY 0xFFC0 TO 0xFFFF; Reserved for Interrupt Vectors */ /* banked FLASH ROM */ PPAGE_0 = READ_ONLY 0x008000 TO 0x00A07F; /* PAGE partially contained in ROM segment */ PPAGE_2 = READ_ONLY 0x028000 TO 0x02BFFF; PPAGE_4 = READ_ONLY 0x048000 TO 0x04BFFF; PPAGE_5 = READ_ONLY 0x058000 TO 0x05BFFF; PPAGE_6 = READ_ONLY 0x068000 TO 0x06BFFF; PPAGE_7 = READ_ONLY 0x078000 TO 0x07BFFF; /* PPAGE_1 = READ_ONLY 0x018000 TO 0x01BFFF; PAGE already contained in segment at 0x4000-0x7FFF */ /* PPAGE_3 = READ_ONLY 0x038000 TO 0x03BFFF; PAGE already contained in segment at 0xC000-0xFFFF */ END PLACEMENT /* Here all predefined and user segments are placed into the SEGMENTS defined above. */ DEFAULT_RAM /* non-zero page variables */ INTO RAM,RAM1; _PRESTART, /* startup code */ STARTUP, /* startup data structures */ ROM_VAR, /* constant variables */ STRINGS, /* string literals */ VIRTUAL_TABLE_SEGMENT, /* C++ virtual table segment */ NON_BANKED, /* runtime routines which must not be banked */ DEFAULT_ROM, COPY /* copy down information: how to initialize variables */ INTO ROM; /* ,ROM1: To use "ROM1" as well, pass the option -OnB=b to the compiler */ PAGED_ROM /* routines which can be banked */ INTO PPAGE_0,PPAGE_2,PPAGE_4,PPAGE_5,PPAGE_6,PPAGE_7,ROM1; _DATA_ZEROPAGE, /* zero page variables */ MY_ZEROPAGE INTO Z_RAM; END STACKSIZE 0x50
VECTOR 0 _Startup /* Reset vector: this is the default entry point for an application. */
