在FLASH下载后出现No change to device contents,是不是意味这我的一切工作都是做白工啊。。。。 #!/bin/sh # # This file was automatically generated by the Nios II IDE Flash Programmer. # # It will be overwritten when the flash programmer options change. # cd D:/flash3/hello_led_0/Debug # Creating .flash file for the project "$SOPC_KIT_NIOS2/bin/elf2flash" --base=0x00000000 --end=0x3fffff --reset=0x0 --i nput="hello_led_0.elf" --output="cfi_flash_0.flash" --boot="D:/altera/70/ip/nios 2_ip/altera_nios2/boot_loader_cfi.srec" # Programming flash with the project "$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --base=0x00000000 --sidp=0x00411018 --id=3354069396 --timestamp=1219047976 --instance=0 "cfi_flash_0.flash" Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Reading System ID at address 0x00411018: verified : Checksumming existing contents 00000000 : Verifying existing contents Checksummed/read 1kB in 0.0s Erase not required 00000000 ( 0%): Programming Programmed 1KB in 0.0s No change to device contents Leaving target processor paused
