[求助]关于Memory Compiler.
Memory Compiler是干什么用的??
如果要从事设计Memory Compiler需要学些什么呢?
Each memory compiler is a set of various, parameterized generators. The generators are:
? Layout Generator
: generates an array of custom, pitch-matched leaf cells.
? Schematic Generator & Netlister
: extracts a netlist which can be used for both LVS check and functional verification.
? Function & Timing Model Generators
: for gate level simulation, dynamic/static timing analysis and synthesis
? Symbol Generator
: for schematic capture
? Critical Path Generator & ETC
: there are many special purpose generators such as critical path generator used for both
circuit design and AC timing characterization.
所以memory compiler就是用于生成memory的生成器,这一般是生成可以综合的rtl,当然也可以是只用来仿真用的。
需要学习相关的memory硬件,数字电路设计,rtl,verilog,当然如果是高速的还和工艺有关。
这个版主不太冷 =========================== 我的中电网博客:http://blog.chinaecnet.com/u/20/index.htm
