Finding Your MAC Address A computer's MAC address (Media Access Control - not to be confused with Macintosh) is a unique set of twelve letters and numbers that identifies your network card on the network. Computers with wireless capabilities will have two MAC addresses, one for the wired ethernet connection and one for the wireless connection. We need the wireless MAC address so that your computer can be recognized on WSU Vancouver's wireless network. If you give us the wrong one, you will not be able to get on the network until this is corrected. Windows XP instructions Click on the Start button Click on Run. This will open a text box to type in commands. Type in "cmd" (without the quote marks) and click the OK button. A command window will open. (In Windows Vista, type cmd into the search line) At the command prompt type the following: ipconfig /all Press the enter key. A list of information will show. Look for the MAC number as described above. Write it down. At the command prompt type "exit" (without quotes) to close the window. The picture below is an example of what you may see, depending on your operating system. You may also have a MAC number for "Bridge Ethernet" connection. If you do, then that is the MAC address you need to use in your registration form.
mac的值是设备的序列号,一般不用自己设,有些可以自己改,格式就如图了。 |
