大家好,这是我编的测试模块,但总有很多错误,不知道为什么,请大伙给我看看,谢谢了! `timescale 1ns / 1ps //////////////////////////////////////////////////////////////////////////////// // Company: // Engineer: // // Create Date: 22:39:09 09/16/2008 // Design Name: sdb_check // Module Name: sdb_check_tbw.v // Project Name: ad9430 // Target Device: // Tool versions: // Description: // // Verilog Test Fixture created by ISE for module: sdb_check // // Dependencies: // // Revision: // Revision 0.01 - File Created // Additional Comments: // //////////////////////////////////////////////////////////////////////////////// module sdb_check_tbw_v; // Inputs reg RST; reg CLK; reg [15:0] DATAIN; reg WEN; // Outputs wire DELAY; wire TRANS_HOLD; wire TRANS_START; wire CALEND; wire FULL; wire INPUT_ERRORS; wire PAUSE; wire [15:0] DATAOUT; wire [3:0] CASES; wire ERROR;
reg[15:0] data[20:0]; reg[15:0] data[0]=16'b1010101001010101,//THE judgement of the head of frame; data[1]=16'b1010101001010101, data[2]=16'b0101010101010000, //change to the case check of the frame; data[3]=16'b0101010101010000, data[4]=16'b0101010101011001, //go to the case of trans_start; data[5]=16'b0101010101011010, // GO TO THE CASE OF TRANS_HOLD; data[6]=16'b0101010101011011, //GO TO THE CASE OF DELAY; data[7]=16'b0101010101011100, //GO TO THE CASE OF CALEND; data[8]=16'b0101010101011101, //GO TO THE CASE OF ERROR; data[9]=16'b0101010101010111, //GO TO THE CASE OF FULL; data[10]=16'b0101010101010101, //GO TO THE CASE OF PAUSE; data[11]=16'b0101010101010101, data[12]=16'b1010101001011101;//这种情况是不存在的,错误的; reg[15:0] data[13]=16'b1010101001010101, data[14]=16'b0101010101010000, data[15]=16'b0101010101011001, data[16]=16'b0101010101011010, data[17]=16'b0101010101011011, data[18]=16'b0101010101011100, data[19]=16'b0101010101011111, //错误状态 data[20]=16'b1010101001010101; // Instantiate the Unit Under Test (UUT) sdb_check uut ( .RST(RST), .CLK(CLK), .DATAIN(DATAIN), .WEN(WEN), .DELAY(DELAY), .TRANS_HOLD(TRANS_HOLD), .TRANS_START(TRANS_START), .CALEND(CALEND), .FULL(FULL), .INPUT_ERRORS(INPUT_ERRORS), .PAUSE(PAUSE), .DATAOUT(DATAOUT), .CASES(CASES), .ERROR(ERROR) ); initial begin // Initialize Inputs RST = 0; CLK = 0; DATAIN = 0; WEN = 0; // Wait 100 ns for global reset to finish #100; RST = 1; #100; RST = 0;
// Add stimulus here end always@(posedge CLK) if(!RST) begin for(i=0;i=20;i=i+1) DATAIN=data; end always #500 WEN=~WEN; always #1000 RST=~RST; always #4 CLK=~ CLK;
endmodule
