楼主说的是sdram吗,ssram是不需要clk的哦, Nios II 和SDRAM时钟相位计算:http://bbs.eccn.com/ecbbs/dispbbs.asp?boardID=9&ID=36114&page=1 generic(SSRAM_HADR:integer:=14); port(phy_clk,wclk,rst:in std_logic; sram_adr:buffer std_logic_vector(SSRAM_HADR downto 0); sram_din:in std_logic_vector(31 downto 0); sram_dout:buffer std_logic_vector(31 downto 0); sram_re,sram_we:ut std_logic; --SSRAM接口 madr:in std_logic_vector(SSRAM_HADR downto 0); mdout :ut std_logic_vector(31 downto 0); mdin:in std_logic_vector(31 downto 0); mwe:in std_logic; mreq:in std_logic; mack:buffer std_logic; --内部DMA操作接口 wadr:in std_logic_vector(SSRAM_HADR downto 0); wdout:ut std_logic_vector(31 downto 0); wdin:in std_logic_vector(31 downto 0); wwe:in std_logic; wreq:in std_logic; wack:buffer std_logic --应用模块的wishbone接口 ); end entity; |
