实体含generic的testbench怎么写??急切请教
entity adder is
generic(n : integer :=8);
port ( a : in std_logic_vector((n-1) downto 0);
b : in std_logic_vector((n-1) downto 0);
c : out std_logic_vector((n-1) downto 0));
end adder;
这样的实体在testbench中怎么写map?我这样写不对:
library ieee;
use ieee.std_logic_1164.all;
entity test_adder is
end test_adder ;
architecture test _bench of test_adder is
component adder
end component;
signal a std_logic_vector((n-1) downto 0);
signal b std_logic_vector((n-1) downto 0);
signal c std_logic_vector((n-1) downto 0);
begin
U : adder generic map(8);
port map (a,b,c);
(其余略)
end test _bench ;
这不对啊,应该怎么写呢?
FPGA内的布局布线有什么规则啊?求求路过的人告诉我
