Warning : SOPC Builder system component lan91c111 is not supported by the simula tor. Simulation may be incorrect if your software attempts to access it Warning : SOPC Builder system component button_pio is not supported by the simul ator. Simulation may be incorrect if your software attempts to access it Warning : SOPC Builder system component led_pio is not supported by the simulato r. Simulation may be incorrect if your software attempts to access it Warning : SOPC Builder system component lcd_display is not supported by the simu lator. Simulation may be incorrect if your software attempts to access it Warning : SOPC Builder system component seven_seg_pio is not supported by the si mulator. Simulation may be incorrect if your software attempts to access it Warning : SOPC Builder system component reconfig_request_pio is not supported by the simulator. Simulation may be incorrect if your software attempts to access it Warning : SOPC Builder system component sysid is not supported by the simulator. Simulation may be incorrect if your software attempts to access it Warning : SOPC Builder system component pll is not supported by the simulator. S imulation may be incorrect if your software attempts to access it ———————————————————————————————— [em06][em06] |
