在利用Altera SOPC Builder建立系统是出现的错误,希望大虾帮忙解决
# 2008.10.06 11:09:31 (*) Running Generator Program for onu_contrall # 2008.10.06 11:09:35 (*) IP functional simulation model enabled: Uncheck System Generation Simulation box for faster generation if HDL Simulation not required. 'D:/Altera/ip/nios2_ip/altera_nios2/eperl' 不是内部或外部命令,也不是可运行的程序 或批处理文件。
Error: Generator program for module 'onu_contrall' did NOT run successfully. generator cmd was 'd:/altera/quartus/quartus//bin/perl/bin/perl -Id:/altera/quartus/quartus/sopc_builder/bin -Id:/altera/quartus/quartus/sopc_builder/bin/europa -Id:/altera/quartus/quartus/sopc_builder/bin/perl_lib -I. -ID:/Altera/ip/nios2_ip/altera_nios2 -ID:/Altera/ip/sopc_builder_ip/altera_avalon_pio -ID:/Altera/ip/nios2_ip/altera_nios_custom_instr_interrupt_vector -ID:/Altera/ip/nios2_ip/altera_nios_custom_instruction -ID:/Altera/ip/sopc_builder_ip/altera_avalon_onchip_memory2 -ID:/Altera/ip/sopc_builder_ip/altera_avalon_onchip_memory -ID:/Altera/ip/sopc_builder_ip/altera_avalon_mutex -ID:/Altera/ip/sopc_builder_ip/altera_avalon_burst_adapter -ID:/Altera/ip/pci_express_compiler/lib/sopc_builder/altera_avalon_pcie_compiler_adapter -ID:/Altera/ip/sopc_builder_ip/altera_avalon_cf -ID:/Altera/ip/sopc_builder_ip/altera_avalon_spi -ID:/Altera/ip/pci_compiler/lib/sopc_builder/altera_avalon_pci_compiler -ID:/Altera/ip/sopc_builder_ip/altera_avalon_user_defined_interface -ID:/Altera/ip/sopc_builder_ip/altera_avalon_pipeline_bridge -ID:/Altera/ip/nios2_ip/altera_nios_dev_board_stratix_2s60_rohs -ID:/Altera/ip/nios2_ip/altera_nios_custom_instr_bitswap -ID:/Altera/ip/sopc_builder_ip/altera_sopc_builder -ID:/Altera/ip/sopc_builder_ip/altera_avalon_cfi_flash -ID:/Altera/ip/sopc_builder_ip/altera_avalon_pll -ID:/Altera/ip/sopc_builder_ip/altera_avalon_sgdma -ID:/Altera/ip/nios2_ip/altera_nios_custom_instr_floating_point -ID:/Altera/ip/sopc_builder_ip/altera_avalon_epcs_flash_controller -ID:/Altera/ip/sopc_builder_ip/altera_avalon_adapter_upstream_pipeline -ID:/Altera/ip/nios2_ip/altera_nios_dev_kit_stratix_edition_sram -ID:/Altera/ip/triple_speed_ethernet/lib/sopc_builder/altera_triple_speed_ethernet -ID:/Altera/ip/pci_express_compiler/lib/sopc_builder/altera_avalon_pcie_compiler -ID:/Altera/ip/sopc_builder_ip/altera_avalon_lan91c111 -ID:/Altera/ip/nios2_ip/altera_nios_dev_kit_stratix_edition_sram2 -ID:/Altera/ip/sopc_builder_ip/altera_avalon_adapter_downstream_pipeline -ID:/Altera/ip/nios2_ip/altera_nios_dev_board_stratix_1s40 -ID:/Altera/ip/sopc_builder_ip/altera_avalon_uart -ID:/Altera/ip/sopc_builder_ip/altera_avalon_new_sdram_controller -ID:/Altera/ip/ddr2_high_perf/lib/sopc_builder/ddr2_high_perf -ID:/Altera/ip/sopc_builder_ip/altera_avalon_adapter_waitrequest_pipeline -ID:/Altera/ip/sopc_builder_ip/altera_avalon_adapter_slave_y -ID:/Altera/ip/sopc_builder_ip/altera_avalon_clock_adapter -ID:/Altera/ip/pci_compiler/lib/sopc_builder/altera_avalon_pci_compiler_adapter -ID:/Altera/ip/sopc_builder_ip/altera_avalon_mailbox -ID:/Altera/ip/sopc_builder_ip/altera_avalon_asmi -ID:/Altera/ip/sopc_builder_ip/amd_avalon_am29lv065d_flash -ID:/Altera/ip/sopc_builder_ip/altera_avalon_lcd_16207 -ID:/Altera/ip/nios2_ip/altera_nios_custom_instr_endian_converter -ID:/Altera/ip/sopc_builder_ip/altera_avalon_jtag_uart -ID:/Altera/ip/sopc_builder_ip/altera_avalon_adapter_master_y -ID:/Altera/ip/sopc_builder_ip/altera_avalon_endian_adapter -ID:/Altera/ip/nios2_ip/altera_nios_dev_board_cyclone_1c20 -ID:/Altera/ip/nios2_ip/altera_nios_dev_board_stratix_1s10_es -ID:/Altera/ip/sopc_builder_ip/altera_avalon_tri_state_bridge -ID:/Altera/ip/nios2_ip/altera_nios_dev_board_cyclone_2c35 -ID:/Altera/ip/sopc_builder_ip/no_legacy_module -ID:/Altera/ip/sopc_builder_ip/amd_avalon_am29lv128m_flash -ID:/Altera/ip/sopc_builder_ip/altera_avalon_cy7c1380_ssram -ID:/Altera/ip/nios2_ip/altera_nios2 -ID:/Altera/ip/ddr_ddr2_sdram/lib/sopc_builder/ddr_sdram_component -ID:/Altera/ip/sopc_builder_ip/altera_avalon_cs8900 -ID:/Altera/ip/sopc_builder_ip/altera_avalon_performance_counter -ID:/Altera/ip/sopc_builder_ip/altera_avalon_sysid -ID:/Altera/ip/sopc_builder_ip/altera_avalon_fifo -ID:/Altera/ip/ddr_high_perf/lib/sopc_builder/ddr_high_perf -ID:/Altera/ip/nios2_ip/altera_nios_dev_board_stratix_2s60_es -ID:/Altera/ip/ddr_ddr2_sdram/lib/sopc_builder/ddr2_sdram_component -ID:/Altera/ip/sopc_builder_ip/altera_avalon_timer -ID:/Altera/ip/ddr3_high_perf/lib/sopc_builder/ddr3_high_perf -ID:/Altera/ip/nios2_ip/altera_nios_multiply -ID:/Altera/ip/sopc_builder_ip/altera_avalon_dma -ID:/Altera/ip/nios2_ip/altera_nios_dev_board_stratix_1s10 -ID:/Altera/ip/sopc_builder_ip/altera_avalon_clock_crossing -ID:/Altera/ip/nios2_ip/altera_nios_dev_board_stratix_2s60 D:/Altera/ip/nios2_ip/altera_nios2/cpu_core_select.pl --system_name=onu --target_module_name=onu_contrall --system_directory=D:/VHDL/gongcheng --sopc_directory=d:/altera/quartus/quartus/sopc_builder --sopc_lib_path=D:/VHDL/gongcheng+D:/Altera/ip/pci_express_compiler/lib/sopc_builder+D:/Altera/ip/ddr3_high_perf/lib/sopc_builder+D:/Altera/ip/ddr2_high_perf/lib/sopc_builder+D:/Altera/ip/ddr_high_perf/lib/sopc_builder+D:/Altera/ip/sopc_builder_ip+D:/Altera/ip/nios2_ip+D:/Altera/ip/triple_speed_ethernet/lib/sopc_builder+D:/Altera/ip/pci_compiler/lib/sopc_builder+D:/Altera/ip/ddr_ddr2_sdram/lib/sopc_builder+d:/altera/quartus/quartus/sopc_builder/components --generate=1 --verbose=0 --software_only=0 --module_lib_dir=D:/Altera/ip/nios2_ip/altera_nios2 --sopc_quartus_dir=d:/altera/quartus/quartus/ --projectname=ONU.quartus' Error in processing. System NOT successfully generated.
请问是什么问题?怎么解决?我是新手 |
呵呵,楼主大可不必去分析具体的问题,楼主试试最小系统,比如一个片上ram和cpu这些的小系统看看能不能生成sopc,如果都不行,建议重装,多半是软件安装的问题,quarts和nios的版本要一致哦 |
这个版主不太冷
我的中电网博客:http://blog.chinaecnet.com/u/20/index.htm |
很明显是楼主的安装有问题,'D:/Altera/ip/nios2_ip/altera_nios2/eperl' 不是内部或外部命令,也不是可运行的程序或批处理文件。eperl是正常的命令,所以建议楼主重新安装。 |
ERROR: In object '' of class e_process: can't access `user_attributes_names' field known fields are: _AUTOLOAD_ACCEPT_ALL _asynchronous_contents _built _clock _contents _creation_history _object_list _order _parent_set _project_set _reset _reset_default _signal_list _vhdl_files _vhdl_fixes _vhdl_variables clock_level comment indent isa_dummy name output_as_muxes_and_registers paragraph reset_level sensitivity_list known pointers are: _parent _project keys: _AUTOLOAD_ACCEPT_ALL _permitted _pointers by the way, this object is a dummy
Error: Generator program for module 'cpu_0' did NOT run successfully. generator cmd was 'd:/altera/quartus/quartus//bin/perl/bin/perl -Id:/altera/quartus/quartus/sopc_builder/bin -Id:/altera/quartus/quartus/sopc_builder/bin/europa -Id:/altera/quartus/quartus/sopc_builder/bin/perl_lib -I. -ID:/Altera/ip/nios2_ip/altera_nios2 -ID:/Altera/ip/sopc_builder_ip/altera_avalon_onchip_memory2 -ID:/Altera/ip/sopc_builder_ip/altera_avalon_onchip_memory -ID:/Altera/ip/sopc_builder_ip/altera_avalon_mutex -ID:/Altera/ip/sopc_builder_ip/altera_avalon_cf -ID:/Altera/ip/sopc_builder_ip/altera_avalon_user_defined_interface -ID:/Altera/ip/nios2_ip/altera_nios_dev_board_stratix_2s60_rohs -ID:/Altera/ip/nios2_ip/altera_nios_custom_instr_bitswap -ID:/Altera/ip/sopc_builder_ip/altera_avalon_cfi_flash -ID:/Altera/ip/sopc_builder_ip/altera_avalon_pll -ID:/Altera/ip/sopc_builder_ip/altera_avalon_sgdma -ID:/Altera/ip/sopc_builder_ip/altera_avalon_epcs_flash_controller -ID:/Altera/ip/sopc_builder_ip/altera_avalon_adapter_upstream_pipeline -ID:/Altera/ip/nios2_ip/altera_nios_dev_kit_stratix_edition_sram -ID:/Altera/ip/pci_express_compiler/lib/sopc_builder/altera_avalon_pcie_compiler -ID:/Altera/ip/sopc_builder_ip/altera_avalon_lan91c111 -ID:/Altera/ip/nios2_ip/altera_nios_dev_kit_stratix_edition_sram2 -ID:/Altera/ip/sopc_builder_ip/altera_avalon_adapter_downstream_pipeline -ID:/VHDL/gongcheng/DE2_demonstrations/DE2_NIOS_DEVICE_LED/HW/user_logic_SRAM_16Bits_512K -ID:/Altera/ip/sopc_builder_ip/altera_avalon_uart -ID:/Altera/ip/ddr2_high_perf/lib/sopc_builder/ddr2_high_perf -ID:/Altera/ip/sopc_builder_ip/altera_avalon_adapter_waitrequest_pipeline -ID:/Altera/ip/sopc_builder_ip/altera_avalon_adapter_slave_y -ID:/Altera/ip/sopc_builder_ip/altera_avalon_asmi -ID:/Altera/ip/nios2_ip/altera_nios_custom_instr_endian_converter -ID:/Altera/ip/sopc_builder_ip/altera_avalon_jtag_uart -ID:/Altera/ip/sopc_builder_ip/altera_avalon_adapter_master_y -ID:/Altera/ip/nios2_ip/altera_nios_dev_board_cyclone_1c20 -ID:/Altera/ip/sopc_builder_ip/altera_avalon_tri_state_bridge -ID:/Altera/ip/sopc_builder_ip/no_legacy_module -ID:/Altera/ip/sopc_builder_ip/amd_avalon_am29lv128m_flash -ID:/Altera/ip/sopc_builder_ip/altera_avalon_cy7c1380_ssram -ID:/Altera/ip/sopc_builder_ip/altera_avalon_cs8900 -ID:/Altera/ip/sopc_builder_ip/altera_avalon_timer -ID:/Altera/ip/ddr3_high_perf/lib/sopc_builder/ddr3_high_perf -ID:/Altera/ip/sopc_builder_ip/altera_avalon_dma -ID:/Altera/ip/nios2_ip/altera_nios_dev_board_stratix_1s10 -ID:/Altera/ip/sopc_builder_ip/altera_avalon_pio -ID:/Altera/ip/nios2_ip/altera_nios_custom_instruction -ID:/Altera/ip/nios2_ip/altera_nios_custom_instr_interrupt_vector -ID:/VHDL/gongcheng/DE2_demonstrations/DE2_NIOS_DEVICE_LED/HW/user_logic_SEG7_LUT_8 -ID:/Altera/ip/sopc_builder_ip/altera_avalon_burst_adapter -ID:/Altera/ip/pci_express_compiler/lib/sopc_builder/altera_avalon_pcie_compiler_adapter -ID:/Altera/ip/sopc_builder_ip/altera_avalon_spi -ID:/Altera/ip/pci_compiler/lib/sopc_builder/altera_avalon_pci_compiler -ID:/Altera/ip/sopc_builder_ip/altera_avalon_pipeline_bridge -ID:/Altera/ip/sopc_builder_ip/altera_sopc_builder -ID:/Altera/ip/nios2_ip/altera_nios_custom_instr_floating_point -ID:/VHDL/gongcheng/DE2_demonstrations/DE2_NIOS_DEVICE_LED/HW/user_logic_Open_I2C -ID:/Altera/ip/triple_speed_ethernet/lib/sopc_builder/altera_triple_speed_ethernet -ID:/Altera/ip/nios2_ip/altera_nios_dev_board_stratix_1s40 -ID:/Altera/ip/sopc_builder_ip/altera_avalon_new_sdram_controller -ID:/Altera/ip/sopc_builder_ip/altera_avalon_clock_adapter -ID:/Altera/ip/sopc_builder_ip/altera_avalon_mailbox -ID:/Altera/ip/pci_compiler/lib/sopc_builder/altera_avalon_pci_compiler_adapter -ID:/Altera/ip/sopc_builder_ip/altera_avalon_lcd_16207 -ID:/Altera/ip/sopc_builder_ip/amd_avalon_am29lv065d_flash -ID:/Altera/ip/sopc_builder_ip/altera_avalon_endian_adapter -ID:/Altera/ip/nios2_ip/altera_nios_dev_board_stratix_1s10_es -ID:/Altera/ip/nios2_ip/altera_nios_dev_board_cyclone_2c35 -ID:/Altera/ip/nios2_ip/altera_nios2 -ID:/Altera/ip/ddr_ddr2_sdram/lib/sopc_builder/ddr_sdram_component -ID:/Altera/ip/sopc_builder_ip/altera_avalon_performance_counter -ID:/Altera/ip/sopc_builder_ip/altera_avalon_sysid -ID:/Altera/ip/sopc_builder_ip/altera_avalon_fifo -ID:/Altera/ip/ddr_high_perf/lib/sopc_builder/ddr_high_perf -ID:/Altera/ip/ddr_ddr2_sdram/lib/sopc_builder/ddr2_sdram_component -ID:/Altera/ip/nios2_ip/altera_nios_dev_board_stratix_2s60_es -ID:/Altera/ip/nios2_ip/altera_nios_multiply -ID:/Altera/ip/sopc_builder_ip/altera_avalon_clock_crossing -ID:/Altera/ip/nios2_ip/altera_nios_dev_board_stratix_2s60 D:/Altera/ip/nios2_ip/altera_nios2/cpu_core_select.pl --system_name=nios_0 --target_module_name=cpu_0 --system_directory=D:/VHDL/gongcheng/DE2_demonstrations/DE2_NIOS_DEVICE_LED/HW --sopc_directory=d:/altera/quartus/quartus/sopc_builder --sopc_lib_path=D:/VHDL/gongcheng/DE2_demonstrations/DE2_NIOS_DEVICE_LED/HW+D:/Altera/ip/pci_express_compiler/lib/sopc_builder+D:/Altera/ip/ddr3_high_perf/lib/sopc_builder+D:/Altera/ip/ddr2_high_perf/lib/sopc_builder+D:/Altera/ip/ddr_high_perf/lib/sopc_builder+D:/Altera/ip/sopc_builder_ip+D:/Altera/ip/nios2_ip+D:/Altera/ip/triple_speed_ethernet/lib/sopc_builder+D:/Altera/ip/pci_compiler/lib/sopc_builder+D:/Altera/ip/ddr_ddr2_sdram/lib/sopc_builder+d:/altera/quartus/quartus/sopc_builder/components --generate=1 --verbose=0 --software_only=0 --module_lib_dir=D:/Altera/ip/nios2_ip/altera_nios2 --sopc_quartus_dir=d:/altera/quartus/quartus/ --projectname=DE2_NIOS_DEVICE_LED.quartus' Error in processing. System NOT successfully generated.
但出现了这个问题 是不是与我系统的名字有关 |
