SOPC生成系统是出现的问题 请大虾帮忙解决
ERROR:
In object '' of class e_process: can't access `user_attributes_names' field
known fields are:
_AUTOLOAD_ACCEPT_ALL
_asynchronous_contents
_built
_clock
_contents
_creation_history
_object_list
_order
_parent_set
_project_set
_reset
_reset_default
_signal_list
_vhdl_files
_vhdl_fixes
_vhdl_variables
clock_level
comment
indent
isa_dummy
name
output_as_muxes_and_registers
paragraph
reset_level
sensitivity_list
known pointers are:
_parent
_project
keys:
_permitted
_pointers
by the way, this object is a dummy
Error: Generator program
for module 'cpu_0' did NOT run successfully.
不管是大点的系统还是小的系统都会出现上面的问题 ?请大虾帮忙解决
楼主把软件环境重新安装一下吧。
在交流中前进,共同实现nios的应用。
和我的情况一样的,估计要重装系统的
重装重装
