我想编一个加法器和减法器集成的程序,但似乎掉用元件的语句属于并行,而process是串行的,怎么处理呢,我需要一个if来作筛选 library ieee; use ieee.std_logic_1164.all; entity plus is port( judge: in std_logic; oper1,oper2:in std_logic_vector(3 downto 0); result1,result2ut std_logic_vector(3 downto 0); rout1,rout2ut std_logic); end entity plus; architecture a of plus is component adder port( a,b:in std_logic_vector(3 downto 0); sut std_logic_vector(3 downto 0); coutut std_logic); end component; component minus port( a,b:in std_logic_vector(3 downto 0); sut std_logic_vector(3 downto 0); coutut std_logic); end component; begin u1:adder port map(a=>oper1,b=>oper2,s1=>result,cout1=>rout); u1:minus port map(a=>oper1,b=>oper2,s2=>result,cout2=>rout); end a;
[此贴子已经被作者于2008-10-10 13:14:39编辑过] |
