[求助]
[求助]
那位大哥 能帮小弟看看这个程序怎么发不出数去啊 我都要疯了 好几天就看这几句话 也调不通
我在这里谢谢了 帮我看看 这个can程序吧。
#include <hidef.h> /* common defines and macros */
#include <mc9s12dg256.h> /* derivative information */
#pragma LINK_INFO DERIVATIVE "mc9s12dg256b"
unsigned char data0;
unsigned char id0=0x12;
unsigned char id1=0x00;
unsigned char len=0x08;
unsigned char data1[8]={0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07};
void DELAYNS(unsigned int k)
unsigned int j=10000;
while(j--)
for(;k>0;k--);
void CAN_Init(void) {
CAN0CTL0 = 0x01;
while(!(0x01&CAN0CTL1));
CAN0CTL1_CANE = 1;
CAN0CTL1_LISTEN = 0;
CAN0BTR0 = 0x01;
CAN0BTR1 = 0x10;
CAN0IDAC = 0X10;
CAN0CTL0_INITRQ = 0;
while((0x01&CAN0CTL1)!=0);
void CAN_Send(void){
unsigned char txbuf;
CAN0TBSEL = CAN0TFLG;
txbuf = CAN0TBSEL;
CAN0TXIDR0 = id0;
CAN0TXIDR1 = id1;
CAN0TXDSR0 = data1[0];
CAN0TXDSR1 = data1[1];
CAN0TXDSR2 = data1[2];
CAN0TXDSR3 = data1[3];
CAN0TXDSR4 = data1[4];
CAN0TXDSR5 = data1[5];
CAN0TXDSR6 = data1[6];
CAN0TXDSR7 = data1[7];
CAN0TXDLR = len;
CAN0TXTBPR = 0;
CAN0TFLG = txbuf;
void main(void) {
unsigned int i;
DELAYNS(0x4000);
CAN_Init();
DELAYNS(0x4000);
for(i=0;i<100;i++){
DELAYNS(0x1000);
DELAYNS(0x1000);
DELAYNS(0x1000);
CAN_Send();
人生若只如初见,何故秋风悲画扇?
收发器的使能在哪里?
是canl、canh上没信号还是tx脚上没信号?
不是CAN0TBSEL = CAN0TFLG; CAN0TFLG = txbuf;
这两条语句控制的吗 ?
tx上就没信号。各位 帮帮我把 我真的没办法了 等着用这个呢 。
人生若只如初见,何故秋风悲画扇?
CAN0CTL1_CANE = 1;
这个是啊
人生若只如初见,何故秋风悲画扇?
没使能transceiver的话,TX脚信号还是应该有的。
can的时钟源再选一下。
CAN0CTL1_CLKSRC
0 -> Oscillator Clock as MSCAN clock
1 -> Bus Clock as MSCAN clock
[此贴子已经被作者于2008-11-4 10:24:45编辑过]
