包括rs232文件发送程序 232.h /**************************************************************************/ /* LabWindows/CVI User Interface Resource (UIR) Include File */ /* Copyright (c) National Instruments 2006. All Rights Reserved. */ /* */ /* WARNING: Do not add to, delete from, or otherwise modify the contents */ /* of this include file. */ /**************************************************************************/ #include <userint.h> #ifdef __cplusplus extern "C" { #endif /* Panels and Controls: */ #define PANEL 1 #define PANEL_OKBUTTON_2 2 /* callback function: receivefile */ #define PANEL_OKBUTTON 3 /* callback function: receivefilename */ #define PANEL_STRING_2 4 #define PANEL_QUITBUTTON 5 /* callback function: QuitCallback */ #define PANEL_STRING 6 #define PANEL_DECORATION_2 7 #define PANEL_COMMANDBUTTON 8 /* callback function: filesel */ #define PANEL_DECORATION 9 #define PANEL_TEXTMSG 10 #define PANEL_TEXTMSG_2 11 /* Menu Bars, Menus, and Menu Items: */
/* (no menu bars in the resource file) */ /* Callback Prototypes: */
int CVICALLBACK filesel(int panel, int control, int event, void *callbackData, int eventData1, int eventData2); int CVICALLBACK QuitCallback(int panel, int control, int event, void *callbackData, int eventData1, int eventData2); int CVICALLBACK receivefile(int panel, int control, int event, void *callbackData, int eventData1, int eventData2); int CVICALLBACK receivefilename(int panel, int control, int event, void *callbackData, int eventData1, int eventData2); #ifdef __cplusplus } #endif
#include <ansi_c.h> #include <utility.h> #include <rs232.h> #include <cvirte.h> #include <userint.h> #include "232.h" static int byteswritten; static char filename[MAX_FILENAME_LEN]; static char pathname[MAX_PATHNAME_LEN]; static int panelHandle; int main (int argc, char *argv[]) { if (InitCVIRTE (0, argv, 0) == 0) return -1; /* out of memory */ if ((panelHandle = LoadPanel (0, "232.uir", PANEL)) < 0) return -1;
//打开并配置串口Com1 OpenComConfig (1, "", 57600, 1, 8, 1, 32767, 32767);
//设置通信超时时间 SetComTime (1, 5.0);
//禁止串口软件握手 SetXMode (1, 0);
//禁止硬件握手 SetCTSMode (1, LWRS_HWHANDSHAKE_OFF); DisplayPanel (panelHandle); RunUserInterface (); DiscardPanel (panelHandle); return 0; } int CVICALLBACK sendfilename (int panel, int control, int event, void *callbackData, int eventData1, int eventData2) { int comstatus; int outputqueuelen; switch (event) { case EVENT_COMMIT: strcat (filename, "\r");
//向Com1写入文件名字符串 byteswritten = ComWrt (1, filename, strlen(filename)); break; } return 0; } int CVICALLBACK QuitCallback (int panel, int control, int event, void *callbackData, int eventData1, int eventData2) { switch (event) { case EVENT_COMMIT:
//关闭串口Com1 CloseCom (1); QuitUserInterface (0); break; } return 0; } int CVICALLBACK filesel (int panel, int control, int event, void *callbackData, int eventData1, int eventData2) { int selstatus; switch (event) { case EVENT_COMMIT: filename[0] = '\0'; selstatus = FileSelectPopup ("", "*.*", "*.*", "打开文件", VAL_LOAD_BUTTON, 0, 0, 1, 1, pathname); if (selstatus >= 0) { SetCtrlVal (panelHandle, PANEL_STRING, pathname);
//获得文件名 SplitPath (pathname, NULL, NULL, filename); } break; } return 0; } int CVICALLBACK sendfile (int panel, int control, int event, void *callbackData, int eventData1, int eventData2) { int outputqueuelen; switch (event) { case EVENT_COMMIT:
//设置串口Com1调制解调器参数 XModemConfig (1, 10.0, 10, 5.0, 1024);
//设置从串口Com1发送文件数据 XModemSend (1, pathname);
//获得串口Com1输出队列的字符串数目 outputqueuelen = GetOutQLen (1); if (outputqueuelen == 0) { MessagePopup ("文件传输", "文件传输完毕!"); } break; } return 0; }
接收程序 #include "toolbox.h" #include <ansi_c.h> #include <rs232.h> #include <cvirte.h> #include <userint.h> #include "232.h" static int bytesread; static char filename[MAX_PATHNAME_LEN]; static char pathname[MAX_PATHNAME_LEN]; static int panelHandle; int main (int argc, char *argv[]) { if (InitCVIRTE (0, argv, 0) == 0) return -1; /* out of memory */ if ((panelHandle = LoadPanel (0, "232.uir", PANEL)) < 0) return -1;
//打开并配置串口Com2 OpenComConfig (2, "", 57600, 1, 8, 1, 32767, 32767);
//设置通信超时时间 SetComTime (2, 5.0);
//禁止串口软件握手 SetXMode (2, 0);
//禁止硬件握手 SetCTSMode (2, LWRS_HWHANDSHAKE_OFF); DisplayPanel (panelHandle); RunUserInterface (); DiscardPanel (panelHandle); return 0; } int CVICALLBACK receivefilename (int panel, int control, int event, void *callbackData, int eventData1, int eventData2) { switch (event) { case EVENT_COMMIT: filename[0] = '\0'; SetCtrlVal (panelHandle, PANEL_STRING, "");
//读取字符串直到回车符出现 bytesread = ComRdTerm (2, filename, 260, 13);
//当出现回车符后,在其后加上结束符 filename[bytesread]= '\0'; SetCtrlVal (panelHandle, PANEL_STRING, filename); break; } return 0; } int CVICALLBACK QuitCallback (int panel, int control, int event, void *callbackData, int eventData1, int eventData2) { switch (event) { case EVENT_COMMIT:
//关闭串口Com2 CloseCom (2); QuitUserInterface (0); break; } return 0; } int CVICALLBACK filesel (int panel, int control, int event, void *callbackData, int eventData1, int eventData2) { int selstatus; switch (event) { case EVENT_COMMIT: selstatus = DirSelectPopup ("", "保存文件", 1, 1, pathname); if (selstatus) { strcat (pathname, "\\"); strcat (pathname, filename); SetCtrlVal (panelHandle, PANEL_STRING_2, pathname); } break; } return 0; } int CVICALLBACK receivefile (int panel, int control, int event, void *callbackData, int eventData1, int eventData2) { int result; int filesize; int inputqueuelen; FILE *stream; switch (event) { case EVENT_COMMIT: GetCtrlVal (panelHandle, PANEL_STRING_2, pathname);
//判断文件是否存在 result = FileExists (pathname, &filesize); if (!result) { stream = fopen (pathname, "wb+"); fclose (stream); }
//设置串口Com2调制解调器参数 XModemConfig (2, 10.0, 10, 5.0, 1024);
//设置从串口Com2接收文件数据 XModemReceive (2, pathname);
//获得串口Com2输入队列的字符串数目 inputqueuelen = GetInQLen (2); if (inputqueuelen == 0) { MessagePopup ("文件保存", "文件保存完毕!"); } break; } return 0; }
