增减计数器
增减计数器
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity count is
port(clk,dir,rst:in std_logic;
count:buffer std_logic_vector(3 downto 0));
end count;
architecture Behavioral of count is
begin
process(clk,dir,rst)
begin
if(rst='1')then
count<="0001";
else
if(clk'event and clk='1')then
if(dir='1')then
count<=count+1;
else
count<=count-1;
end if;
end if;
end if;
end process;
end Behavioral;
请问为什么以上代码可以综合,但是无法仿真呢???
ERROR:HDLParsers:1202 - "E:/kao2/gfdh.vhw" Line 43. Redeclaration of symbol count.
ERROR:HDLParsers:402 - "E:/kao2/gfdh.vhw" Line 58. Component 'count' count can not be used as a primary name.
Parsing "gfdh_beh.prj": 0.11
ERROR: Fuse failed
以上是仿真时的报错
[em66][em66][em66][em66][em66][em66][em66][em66][em66][em107][em107][em107][em107]
-- Copyright (c) 1995-2003 Xilinx, Inc.
-- All Right Reserved.
-- ____ ____
-- /___/ \ / Vendor: Xilinx
-- \ \ \/ Version : 7.1i
-- \ \ Application : ISE Foundation
-- / / Filename : gfdh.vhw
-- /___/ /\ Timestamp : Wed Nov 05 23:32:54 2008
-- \___\/\___\
--Command:
--Design Name: gfdh
--Device: Xilinx
library IEEE;
USE IEEE.STD_LOGIC_TEXTIO.ALL;
USE STD.TEXTIO.ALL;
ENTITY gfdh IS
END gfdh;
ARCHITECTURE testbench_arch OF gfdh IS
COMPONENT count
PORT (
clk : In std_logic;
dir : In std_logic;
rst : In std_logic;
count : Buffer std_logic_vector (3 DownTo 0)
END COMPONENT;
SIGNAL clk : std_logic := '0';
SIGNAL dir : std_logic := '0';
SIGNAL rst : std_logic := '1';
SIGNAL count : std_logic_vector (3 DownTo 0) := "0000";
SHARED VARIABLE TX_ERROR : INTEGER := 0;
SHARED VARIABLE TX_OUT : LINE;
constant PERIOD : time := 200 ns;
constant DUTY_CYCLE : real := 0.5;
constant OFFSET : time := 0 ns;
BEGIN
UUT : count
PORT MAP (
clk => clk,
dir => dir,
rst => rst,
count => count
PROCESS -- clock process for clk
BEGIN
WAIT for OFFSET;
CLOCK_LOOP : LOOP
clk <= '0';
WAIT FOR (PERIOD - (PERIOD * DUTY_CYCLE));
clk <= '1';
WAIT FOR (PERIOD * DUTY_CYCLE);
END LOOP CLOCK_LOOP;
END PROCESS;
PROCESS
BEGIN
-- ------------- Current Time: 1085ns
WAIT FOR 1085 ns;
dir <= '1';
rst <= '0';
-- ------------- Current Time: 4085ns
WAIT FOR 3000 ns;
dir <= '0';
-- ------------- Current Time: 6885ns
WAIT FOR 2800 ns;
dir <= '1';
-- ------------- Current Time: 9085ns
WAIT FOR 2200 ns;
rst <= '1';
WAIT FOR 1115 ns;
IF (TX_ERROR = 0) THEN
STD.TEXTIO.write(TX_OUT, string'("No errors or warnings"));
ASSERT (FALSE) REPORT
"Simulation successful (not a failure). No problems detected."
SEVERITY FAILURE;
ELSE
STD.TEXTIO.write(TX_OUT, TX_ERROR);
string'(" errors found in simulation"));
ASSERT (FALSE) REPORT "Errors found during simulation"
SEVERITY FAILURE;
END IF;
END PROCESS;
END testbench_arch;
补上
[em72][em72][em72]
library IEEE;
USE STD.TEXTIO.ALL;
ENTITY gfdh IS
END gfdh;
COMPONENT count
PORT (
clk : In std_logic;
dir : In std_logic;
rst : In std_logic;
END COMPONENT;
BEGIN
UUT : count
PORT MAP (
clk => clk,
dir => dir,
rst => rst,
count => count
BEGIN
WAIT for OFFSET;
CLOCK_LOOP : LOOP
clk <= '0';
clk <= '1';
END PROCESS;
PROCESS
BEGIN
WAIT FOR 1085 ns;
dir <= '1';
rst <= '0';
WAIT FOR 3000 ns;
dir <= '0';
WAIT FOR 2800 ns;
dir <= '1';
WAIT FOR 2200 ns;
rst <= '1';
WAIT FOR 1115 ns;
SEVERITY FAILURE;
ELSE
SEVERITY FAILURE;
END IF;
END PROCESS;
END testbench_arch;
不好意思,上面那个,不完全
[em72]
呃……没办法一次发完…………
[em61][em61][em61][em61]
我是新手,刚刚没弄清楚,原来重新进入就可以看到全部内容了,请各位就看最上面的两份帖子[em72][em72][em72][em72][em72][em72]
解决了是也
