[求助]求救: 下载EPCS16
[求助]求救: 下载EPCS16
FPGA芯片:EP3C10F256C8 配置芯片:EPCS16 7.2版的环境
我用flash programmer的时候出现以下问题
#!/bin/sh
# This file was automatically generated by the Nios II IDE Flash Programmer.
# It will be overwritten when the flash programmer options change.
cd D:/zzz/software/hello_led_0/Debug
# Creating .flash file for the FPGA configuration
"$SOPC_KIT_NIOS2/bin/sof2flash" --epcs --input="D:/zzz/zzz.sof" --output="zzz.fl
ash"
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert --device=EPCS64 --option=zzz.op
t D:/zzz/zzz.sof zzz.pof
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Allocated 60 megabytes of memory during processing
Info: Processing ended: Fri Nov 14 17:50:29 2008
Info: Elapsed time: 00:00:02
Info: Command: quartus_cpf --no_banner --convert zzz.pof zzz.rpd
Info: Allocated 57 megabytes of memory during processing
Info: Processing ended: Fri Nov 14 17:50:30 2008
Info: Elapsed time: 00:00:01
# Programming flash with the FPGA configuration
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x00009800 --cable='U
SB-Blaster [USB-0]' "zzz.flash"
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: OK
No EPCS layout data - looking for section [EPCS-FF]
Unable to use EPCS device
Leaving target processor paused
# Creating .flash file for the project
"$SOPC_KIT_NIOS2/bin/elf2flash" --epcs --after="zzz.flash" --input="hello_led_0.
elf" --output="epcs_controller.flash"
# Programming flash with the project
SB-Blaster [USB-0]' "epcs_controller.flash"
怎么会出现EPCS64呢?帮忙一下?
