CODEWARRIOR中断写法
CODEWARRIOR中断写法
方法1
interrupt 3 IntFunc1()
…/*code*/
Means that the third entry in the vector table is initialized with the address of IntFunc1().
方法2
In the C file:
interrupt IntFunc2()
In the PRM file:
VECTOR ADRESS 0xFFF2 IntFunc2
Means that the address of IntFunc2 is written at address 0xFFF2.
这个错了,0xFFF2是中断向量,存放的是中断程序的入口地址。
格式本身没错,但应该是ADDRESS。
海纳百川  有容乃大
