[求助]Nios II IDE 编译时出现的问题
再利用NiosII编译时,出现
This problem is probably due to using incompatible versions of the cygwin DLL.
Search for cygwin1.dll using the Windows Start->Find/Search facility
and delete all but the most recent version. The most recent version *should*
reside in x:\cygwin\bin, where 'x' is the drive on which you have
installed the cygwin distribution. Rebooting is also suggested if you
are unable to find another cygwin DLL.
什么问题呢?
有可能是你的nios和quartus 的版本不一致造成的
