今天做时序约束时,为了观测setup/hold时间,约束条件比较苛刻,故意使setup/hold要求不满足,但在analyze post-place& route static time分析报告里发现奇怪的问题,程序里只使用一个寄存器,但分析setup和hold时间,每个部分的datapath和clockpath居然不一样,按照理解,从clk或者data到这个寄存器只有一个物理通道,这些延迟也只有一个,不知何故?下面是时序报告,请大侠指教!! ================================================================================ Timing constraint: COMP "a" OFFSET = IN 0.5 ns VALID 0.5 ns BEFORE COMP "clk"; 1 item analyzed, 2 timing errors detected. (1 setup error, 1 hold error) Minimum allowable offset is 0.737ns. -------------------------------------------------------------------------------- Slack: -0.237ns (requirement - (data path - clock path - clock arrival + uncertainty)) Source: a (PAD) Destination: ov (FF) Destination Clock: clk_buf rising at 1.250ns Requirement: 0.500ns Data Path Delay: 3.163ns (Levels of Logic = 1) Clock Path Delay: 1.176ns (Levels of Logic = 3) Clock Uncertainty: 0.000ns Timing Improvement Wizard Data Path: a to ov Delay type Delay(ns) Logical Resource(s) ---------------------------- ------------------- Tiopi 1.726 a U0IBUF net (fanout=1) 1.055 a_buf Tdick 0.382 ov ---------------------------- --------------------------- Total 3.163ns (2.108ns logic, 1.055ns route) (66.6% logic, 33.4% route) Clock Path: clk to ov Delay type Delay(ns) Logical Resource(s) ---------------------------- ------------------- Tiopi 1.466 clk Udcm_1/CLKIN_IBUFG_INST net (fanout=1) 0.577 Udcm_1/CLKIN_IBUFG_OUT Tdcmino -2.404 Udcm_1/DCM_SP_INST net (fanout=1) 0.319 Udcm_1/CLK90_BUF Tgi0o 1.166 Udcm_1/CLK90_BUFG_INST net (fanout=1) 0.052 clk_buf ---------------------------- --------------------------- Total 1.176ns (0.228ns logic, 0.948ns route) -------------------------------------------------------------------------------- Hold Paths: COMP "a" OFFSET = IN 0.5 ns VALID 0.5 ns BEFORE COMP "clk"; -------------------------------------------------------------------------------- Slack (hold path): -0.559ns (requirement - (clock path + clock arrival + uncertainty - data path)) Source: a (PAD) Destination: ov (FF) Destination Clock: clk_buf rising at 1.250ns Requirement: 0.000ns Data Path Delay: 2.462ns (Levels of Logic = 1) Clock Path Delay: 1.771ns (Levels of Logic = 3) Clock Uncertainty: 0.000ns Timing Improvement Wizard Data Path: a to ov Delay type Delay(ns) Logical Resource(s) ---------------------------- ------------------- Tiopi 1.466 a U0IBUF net (fanout=1) 0.844 a_buf Tckdi (-Th) -0.152 ov ---------------------------- --------------------------- Total 2.462ns (1.618ns logic, 0.844ns route) (65.7% logic, 34.3% route) Clock Path: clk to ov Delay type Delay(ns) Logical Resource(s) ---------------------------- ------------------- Tiopi 1.726 clk Udcm_1/CLKIN_IBUFG_INST net (fanout=1) 0.721 Udcm_1/CLKIN_IBUFG_OUT Tdcmino -2.592 Udcm_1/DCM_SP_INST net (fanout=1) 0.398 Udcm_1/CLK90_BUF Tgi0o 1.457 Udcm_1/CLK90_BUFG_INST net (fanout=1) 0.061 clk_buf ---------------------------- --------------------------- Total 1.771ns (0.591ns logic, 1.180ns route)
