求助strongchen:移植uC/OS-II过程中的error
Error : C4437: Error-directive found: OS_CFG.H, Missing OS_FLAG_EN: Enable (1) or Disable (0) code generation for Event Flags
uCOS_II.H line 865
Error : C4437: Error-directive found: OS_CFG.H, Missing OS_MBOX_EN: Enable (1) or Disable (0) code generation for MAILBOXES
uCOS_II.H line 902
Error : C4437: Error-directive found: OS_CFG.H, Missing OS_MEM_EN: Enable (1) or Disable (0) code generation for MEMORY MANAGER
uCOS_II.H line 932
Error : C4437: Error-directive found: OS_CFG.H, Missing OS_MUTEX_EN: Enable (1) or Disable (0) code generation for MUTEX
uCOS_II.H line 957
Error : Compile failed
