求救:如何用PE开发串口和用示波器观测
求救:如何用PE开发串口和用示波器观测
我用PE开发MC56F8037的板子,发现用示波器观察总看不到信号 程序如下
#include "Cpu.h"
#include "SCI1.h"
/* Include shared modules, which are used for whole project */
#include "PE_Types.h"
#include "PE_Error.h"
#include "PE_Const.h"
#include "IO_Map.h"
unsigned char data=127;
void tr(void)
{ unsigned char tr_clear;
while((QSCI0_STAT&QSCI0_STAT_TDRE_MASK)==0);tr_clear=QSCI0_STAT;
QSCI0_DATA=data;
void main(void)
/* Write your local variable definition here */
/*** Processor Expert internal initialization. DON'T REMOVE THIS CODE!!! ***/
PE_low_level_init();
/*** End of Processor Expert internal initialization. ***/
QSCI0_CTRL1|=QSCI0_CTRL1_TE_MASK;
/* Write your code here */
SCI1_Init();
for(;;) { tr();
void isr_re(void)
void SCI1_Init(void)
/* QSCI0_RATE: SBR=0xD0,FRAC_SBR=3 */
setReg16(QSCI0_RATE, 0x0683); /* Set prescaler bits */
/* QSCI0_CTRL1: LOOP=0,SWAI=0,RSRC=0,M=0,WAKE=0,POL=0,PE=0,PT=0,TEIE=0,TIIE=0,RFIE=1,REIE=0,TE=1,RE=0,RWU=0,SBK=0 */
setReg16(QSCI0_CTRL1, 0x28); /* Set the SCI control register */
/* QSCI0_CTRL2: TFCNT=0,TFWM=0,RFCNT=0,RFWM=0,FIFO_EN=0,??=0,LIN_MODE=0,??=0,??=0,??=0 */
setReg16(QSCI0_CTRL2, 0x00); /* Set the SCI control register */
谢谢啦,哪位朋友如果也在搞DSP,交个朋友吧,我的QQ:314098539
现在正用mc9s12hz64
也正在调串口,
