大家好: 我使用USB JTAG调试,连接不上,提示 " CCSProtocolPlugin: CCS: Library not found ". My dsc is 56f8323. CCS中输入:SHOW COM (bin) 4 % show com Show commands turned on 显示: Received CMD_CONFIG_CHAIN. count = 0 USB TAP command done - Ok CCSAPI connection #1 accepted from localhost at Wed Feb 11 18:57:27 2009 Received CMD_CHECK_MIN_VERSION command done - Ok Received CMD_AVAILABLE_CONNECTIONS command done - Ok Received CMD_DELETE_CC command done - Ok Received CMD_SETUP_CC.CC = utap: command done - Ok Received CMD_CONFIG_CHAIN. count = 1 core 0: HawkV2 Available USB TAPs: 01002808 Opening connection to USB TAP 01002808 Received an unknown command 45 USB TAP command done - Ok Available USB TAPs: 01002808 Opening connection to USB TAP 01002808 Received an unknown command 46 USB TAP command done - Ok USB TAP command done - Cable disconnected Received CMD_RESET_TO_DEBUG USB TAP command done - Library not found Received CMD_CONFIG_CHAIN. count = 0 USB TAP command done - Ok CCSAPI connection #1 from localhost closed at Wed Feb 11 18:57:29 2009 Received CMD_SERVER_VERSION command done - Ok (bin) 5 % |
