[求助]codewarrior错误提示
[求助]codewarrior错误提示
codewarrior错误提示:
Error :require nop(s) between write to control register and an instruction which is not one of the following: any move, adda, adda.l, suba, nop [D_004b]
dspfunc.c line 29
Project: servo.mcp, Target: sdm pROM-xRAM, Source File: dspfunc.c
Error : Require NOP(s) between write to control register and an instruction which is not one of the following: any move, adda, adda.l, suba, nop [D_004b]
dspfunc.c line 30
Error : Pipeline conflict detected in this function.
dspfunc.c line 32 }
void dspfuncInitialize(void)
/* Set saturation mode, set 2's complement rounding, and reset limit bit */
archSetSat32();
archSet2CompRound();
archResetLimitBit();
请问各位,什么原因?codewarrior错误提示,哪里可以找到?
那你就按错误提示指出的,在相应的地方加上NOP指令试试。
海纳百川  有容乃大
试过了,一样
