代码如下: library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity tTV is port ( clock_50 : in std_logic; TD_DATA : in std_logic_vector(7 downto 0); TD_HS,TD_VS : in std_logic; LEDR : out std_logic_vector(11 downto 0); HEX0 : out std_logic_vector(0 to 6); HEX1 : out std_logic_vector(0 to 6); HEX2 : out std_logic_vector(0 to 6); HEX3 : out std_logic_vector(0 to 6); HEX4 : out std_logic_vector(0 to 6); HEX5 : out std_logic_vector(0 to 6); HEX6 : out std_logic_vector(0 to 6); HEX7 : out std_logic_vector(0 to 6)); end entity tTV; architecture one of tTV is component char_7seg is port( M : in std_logic_vector(3 downto 0); D : out std_logic_vector(0 to 6)); end component char_7seg; signal h_count,v_count,rh,rv : std_logic_vector(11 downto 0); begin process(TD_HS) begin if clock_50='1' and clock_50'event then if TD_HS='0' then h_count<=h_count+1; else h_count<=(others=>'0'); end if; end if; end process;
process(TD_HS) begin if TD_HS='1' and TD_HS'event then rh<=h_count; end if; end process;
process(TD_VS) begin if clock_50='1' and clock_50'event then if TD_VS='0' then v_count<=v_count+1; else v_count<=(others=>'0'); end if; end if; end process;
process(TD_VS) begin if TD_VS='1' and TD_VS'event then rv<=v_count; end if; end process;
u1: char_7seg port map(rh(11 downto 8),HEX0); u2: char_7seg port map(rh(7 downto 4),HEX1); u3: char_7seg port map(rh(3 downto 0),HEX2); u4: char_7seg port map(rv(11 downto 8),HEX3); u5: char_7seg port map(rv(7 downto 4),HEX4); u6: char_7seg port map(rv(3 downto 0),HEX5); u7: char_7seg port map(TD_DATA(7 downto 4),HEX6); u8: char_7seg port map(TD_DATA(3 downto 0),HEX7); end architecture ; library ieee; use ieee.std_logic_1164.all;
entity char_7seg is port( M : in std_logic_vector(3 downto 0); D : out std_logic_vector(0 to 6)); end entity char_7seg; architecture one of char_7seg is signal D0 : std_logic_vector(0 to 6); begin process(M) begin case M is when "0000" => D0 <= "0000001"; when "0001" => D0 <= "1001111"; when "0010" => D0 <= "0010010"; when "0011" => D0 <= "0000110"; when "0100" => D0 <= "1001100"; when "0101" => D0 <= "0100100"; when "0110" => D0 <= "0100000"; when "0111" => D0 <= "0001111"; when "1000" => D0 <= "0000000"; when "1001" => D0 <= "0000100"; when "1010" => D0 <= "0001000"; when "1011" => D0 <= "1100000"; when "1100" => D0 <= "1110010"; when "1101" => D0 <= "1000010"; when "1110" => D0 <= "0110000"; when "1111" => D0 <= "0111000"; when others => D0 <= "1111111"; end case; end process; D <= D0; end architecture; HEX0 ~HEX7:分别为0 0 0 0 0 0 8 8 请问是什么问题啊??代码有错吗? |
