BDM下载程序问题
BDM下载程序问题
请教大家:
我的板子上用的芯片是MC9S12DP512,但P&E BDM-multilink无法下载程序。只能硬件仿真。察看codewarrior的command窗口,有一段似乎异常:
MCU clock speed: 1544000 Hz
Block Module Name Address Range Status
0 EEPROM 1000 - 17FF Blank - Unselected
1 FLASH_4000 4000 - 7FFF Blank - Unselected
2 FLASH_C000 C000 - FFFF Programmed - Unselected
3 PAGED 3C8000 -3FBFFF Programmed - Unselected
The UNPROTECT command is not available for the EEPROM flash module => Skipped.
The UNPROTECT command is not available for the FLASH_4000 flash module => Skipped.
The UNPROTECT command is not available for the FLASH_C000 flash module => Skipped.
The UNPROTECT command is not available for the PAGED flash module => Skipped.
不知为何跳过以上的命令,是否由此导致下载不成功?
兄弟我也遇到这种问题了,求高手指点啊!!! 1# chenlinlinchina
看起来在你的程序中,地址的定义和分配似乎有问题。
海纳百川  有容乃大
