求助(运行 Simple Socket Server 时出现的错误)
我用的开发板是Stratix II EP2S180 DSP Development Board,所用软件都是6.0,在运行nios ii 提供的 Simple Socket Server 例子时时出现一下错误: nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 1 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
Simple Socket Server starting up Your Ethernet MAC address is 00:07:ed:0e:b4:7c
[lwIP]: See STDERR for expanded diagnosis translation. [lwIP]: [init_done_func] Fatal: lwip_devices_init failed, perhaps ethernet inter face. [lwIP]: ERRNO: :
[lwIP]: See STDERR (FAULT_LEVEL is SYSTEM). [lwIP]: FAULT_LEVEL is SYSTEM. [lwIP]: FATAL Error, Restart required. [lwIP]: Locking scheduler - endless loop. 请高手指点,小弟万分感谢! |
可能是硬件有问题,或是驱动有问题。 你看看网络芯片的资料 |
硬件应该没问题,开发板是买的altera公司的,网卡lan91c111的驱动是nios ii 自带的啊! |
