Use DPAGE, PPAGE, EPAGE to specify the page register.
![Rank: 2](images/default/star_level2.gif)
小弟在编译程序时碰到了这样的警告:Use DPAGE, PPAGE, EPAGE to specify the page register。帮助系统告诉我“Compile all your source files with the correct page options (-CpDPage, -CpEPage or -CpPPage )! ”,当我勾选“PPAGE Register is used for paging”选项时,下方又出现了:“-CpPPAGE: PPAGE Register is used for paging(enter [0xaddr | RUNTIME])”,它的默认值是0x35,我用的是S12DG256的片子,这个值该设为多少还是按照默认? |
