C/C++ Indexer Problem...在线等
1 C/C++ Indexer Problem: Syntax error encountered in file:E:\SOPC\core\software\A80B_syslib\Debug\system_description\alt_sys_init.c on line: 86. alt_sys_init.c A80B_syslib/Debug/system_description line 86 April 27, 2009 3:33:12 PM 1 C/C++ Indexer Problem: Syntax error encountered in file: D:\altera\kits\nios2\components\altera_avalon_cfi_flash\HAL\inc\altera_avalon_cfi_flash.h on line: 65. altera_avalon_cfi_flash.h Nios II Device Drivers/altera_avalon_cfi_flash/HAL/inc line 65 April 27, 2009 3:33:12 PM 1 C/C++ Indexer Problem: Syntax error encountered in file: D:\altera\kits\nios2\components\altera_hal\HAL\inc\sys\alt_flash_dev.h on line: 82. alt_flash_dev.h Nios II Device Drivers/altera_hal/HAL/inc/sys line 82 April 27, 2009 3:33:12 PM
不知道为什么会出现这种问题,其结果就是定时器技术有问题,按键扫描不稳定! 在线等,忘大侠赐教~ |
