-------------------------------------------------------------------------------- -- Company: -- Engineer: -- -- Create Date: 11:17:12 04/13/2009 -- Design Name: DDFS -- Module Name: D:/vhdl/dds1/out_txt.vhd -- Project Name: dds1 -- Target Device: -- Tool versions: -- Description: -- -- VHDL Test Bench Created by ISE for module: DDFS -- -- Dependencies: -- -- Revision: -- Revision 0.01 - File Created -- Additional Comments: -- -- Notes: -- This testbench has been automatically generated using types std_logic and -- std_logic_vector for the ports of the unit under test. Xilinx recommends -- that these types always be used for the top-level I/O of a design in order -- to guarantee that the testbench will bind correctly to the post-implementation -- simulation model. -------------------------------------------------------------------------------- LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.std_logic_unsigned.all; USE ieee.numeric_std.ALL;
library STD; use STD.TEXTIO.ALL; ENTITY out_txt_vhd IS END out_txt_vhd; ARCHITECTURE behavior OF out_txt_vhd IS -- Component Declaration for the Unit Under Test (UUT) COMPONENT DDFS PORT( CLK : IN std_logic; reset : IN std_logic; Freq_Data : IN std_logic_vector(13 downto 0); Dout : OUT std_logic_vector(14 downto 0); Dac_clk : OUT std_logic ); END COMPONENT; --Inputs SIGNAL CLK : std_logic := '0'; SIGNAL reset : std_logic := '0'; SIGNAL Freq_Data : std_logic_vector(13 downto 0) := "00011110101110";--(others=>'0'); -- 32109876543210 --Outputs SIGNAL DDS_Out : std_logic_vector(14 downto 0); SIGNAL Dac_clk : std_logic;
file out_file:text is out "d:\out_file.txt"; BEGIN -- Instantiate the Unit Under Test (UUT) uut: DDFS PORT MAP( CLK => CLK, reset => reset, Freq_Data => Freq_Data, Dout => DDS_Out, Dac_clk => Dac_clk ); clk<=not clk after 0.5ns; --100Mhz tb : PROCESS BEGIN reset<='0'; wait for 0.1 ns; -- Wait 20 ns for global reset to finish reset<='1'; -- Place stimulus here wait; -- will wait forever END PROCESS;
PROCESS(DDS_Out) variable out_line:line; begin write(out_line,to_bitvector(DDS_Out)); writeline(out_file,out_line); end process; END;
