用nios环境驱动1602出现的问题
用nios环境驱动1602出现的问题
我用的DE2开发板,SOPC中加了LCD的IP,,引脚肯定没问题了.
nios程序是
//lcd.c
#include <unistd.h>
#include <string.h>
#include <io.h>
#include "system.h"
#include "altera_avalon_pio_regs.h"
#include "LCD.h"
int main (void) __attribute__ ((weak, alias ("alt_main")));
int i;
void LCD_Init()
lcd_write_cmd(LCD_16207_0_BASE,0x38);
usleep(2000);
lcd_write_cmd(LCD_16207_0_BASE,0x0C);
usleep(2000);
lcd_write_cmd(LCD_16207_0_BASE,0x01);
usleep(2000);
lcd_write_cmd(LCD_16207_0_BASE,0x06);
usleep(2000);
lcd_write_cmd(LCD_16207_0_BASE,0x80);
usleep(2000);
void LCD_Show_Text(char* Text)
int i;
for(i=0;i<strlen(Text);i++)
lcd_write_data(LCD_16207_0_BASE,Text);
usleep(2000);
void LCD_Line2()
lcd_write_cmd(LCD_16207_0_BASE,0xC0);
usleep(2000);
void LCD_Test()
char Text1[16] = "1234567 90123456";
char Text2[16] = "1234567890123456";
LCD_Init();
LCD_Show_Text(Text1);
LCD_Line2();
LCD_Show_Text(Text2);
int alt_main(void)
LCD_Test();
return 0;
//lcd.h
#ifndef __LCD_H__
#define __LCD_H__
#include "system.h"
// LCD Module 16*2
#define lcd_write_cmd(base, data) IOWR(base, 0, data)
#define lcd_read_cmd(base) IORD(base, 1)
#define lcd_write_data(base, data) IOWR(base, 2, data)
#define lcd_read_data(base) IORD(base, 3)
#endif
结果是液晶上有显示,位数也对,但是乱码,第一行一个样,第二行一个样.
其中上面红色的那一行有警告:
Multiple markers at this line
-warning: passing arg 2 of `__builtin_stwio' makes integer from pointer
without a cast
-Line breakpoint: hello_world.c [line: 27]
前辈们指教下
谢谢了!
[此贴子已经被作者于2009-6-5 19:12:01编辑过]
