请教中断重定位问题
请教中断重定位问题
版主,请教个问题,我再中断向量重定位时,编译出现下面这种问题,根据提示,我把我的中断向量的定义方式由
typedef void (*near tIsrFunc)(void);改为typedef void (*far tIsrFunc)(void);就不会出现以下问题,但中断入口却丢失了。
请高手帮忙。
const tIsrFunc _vect[] @0x00DF10 = { /* Interrupt table */
UnimplementedISR, //119
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR, //110
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR, //100
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR, //90
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR,
UnimplementedISR, //80
UnimplementedISR,
UnimplementedISR, /* vector 78 */
UnimplementedISR, /* vector 77 */
UnimplementedISR, /* vector 76 */
UnimplementedISR, /* vector 75 */
UnimplementedISR, /* vector 74 */
UnimplementedISR, /* vector 73 */
UnimplementedISR, /* vector 72 */
UnimplementedISR, /* vector 71 */
UnimplementedISR, /* vector 70 */
UnimplementedISR, /* vector 69 */
UnimplementedISR, /* vector 68 */
UnimplementedISR, /* vector 67 */
UnimplementedISR, /* vector 66 */
UnimplementedISR, /* vector 65 */
UnimplementedISR, /* vector 64 */
UnimplementedISR, /* vector 63 */
UnimplementedISR, /* vector 62 */
UnimplementedISR, /* vector 61 */
UnimplementedISR, /* vector 60 */
UnimplementedISR, /* vector 59 */
UnimplementedISR, /* vector 58 */
UnimplementedISR, /* vector 57 */
UnimplementedISR, /* vector 56 */
UnimplementedISR, /* vector 55 */
UnimplementedISR, /* vector 54 */
UnimplementedISR, /* vector 53 */
UnimplementedISR, /* vector 52 */
UnimplementedISR, /* vector 51 */
UnimplementedISR, /* vector 50 */
UnimplementedISR, /* vector 49 */
UnimplementedISR, /* vector 48 */
UnimplementedISR, /* vector 47 */
UnimplementedISR, /* vector 46 */
UnimplementedISR, /* vector 45 */
UnimplementedISR, /* vector 44 */
UnimplementedISR, /* vector 43 */
MSCAN1Rec, /* vector 42 */
CAN1error_int, /* vector 41 */
UnimplementedISR, /* vector 40 */
UnimplementedISR, /* vector 39 */
CAN0rxd_int, /* vector 38 */
CAN0error_int, /* vector 37 */
Can0WakeUpInterrupt, /* vector 36 */
UnimplementedISR, /* vector 35 */
UnimplementedISR, /* vector 34 */
UnimplementedISR, /* vector 33 */
UnimplementedISR, /* vector 32 */
UnimplementedISR, /* vector 31 */
UnimplementedISR, /* vector 30 */
UnimplementedISR, /* vector 29 */
UnimplementedISR, /* vector 28 */
UnimplementedISR, /* vector 27 */
UnimplementedISR, /* vector 26 */
UnimplementedISR, /* vector 25 */
UnimplementedISR, /* vector 24 */
UnimplementedISR, /* vector 23 */
UnimplementedISR, /* vector 22 */
UnimplementedISR, /* vector 21 */
UnimplementedISR, /* vector 20 */
UnimplementedISR, /* vector 19 */
UnimplementedISR, /* vector 18 */
UnimplementedISR, /* vector 17 */
UnimplementedISR, /* vector 16 */
Timer7, /* vector 15 */
Timer6, /* vector 14 */
Timer5, /* vector 13 */
Timer4, /* vector 12 */
Timer3, /* vector 11 */
Timer2, /* vector 10 */
Timer1, /* vector 09 */
Timer0, /* vector 08 */
rti_int, /* vector 07 */
irq_int, /* vector 06 */
UnimplementedISR, /* vector 05 */
UnimplementedISR, /* vector 04 */
UnimplementedISR, /* vector 03 */
WatchDogIsr, /* vector 02 */
_EntryPoint,
_EntryPoint,
看不到错误提示窗口图片。
海纳百川  有容乃大
