[原创]Nios IDE编译时出现如下错误是什么原因?如何解决?
- 女
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Reading System ID at address 0x008048D8: does not match ID value does not match: read 0x0AE76942; expected 0x2187581E Timestamp value does not match: image on board is newer than expected Read timestamp 11:10:58 2009/07/11; expected 8:36:39 2009/07/11 The software you are downloading may not run on the system which is currently configured into the device. Please download the correct SOF or recompile. Restarting target processor 我用sopc做CAN通讯 加了System ID peripheral 和SDRAM, 嵌入了锁相环 编译时出现如上错误 请问是为什么 如何解决?? 谢谢!! |
