请问下面的代码编译以后,为什么addr地址线总是连不上????
library IEEE; use IEEE.std_logic_1164.all;
package instr is type instruction is (add, sub, lda, ldb, sta, stb, outa, xfr); end instr;
use work.instr.all; library IEEE; use IEEE.std_logic_1164.all; use IEEE.std_logic_unsigned.all;
entity mp is port(instr : in instruction; addr : in integer; data : inout integer ); end mp;
architecture mp of mp is begin process(instr, addr) type regtype is array(0 to 255) of integer; variable a, b : integer; variable reg : regtype; begin case instr is --select instr to execute when lda => a := data; --load a accumulator when ldb => b := data; --load b accumulator when add => a := a + b; when sub => a := a - b; when sta => reg(addr) := a; --put a accum into reg array when stb => reg(addr) := b; -- put b accum in to reg array when outa => data <= a; --output a accum when xfr => --transfer b to a a := b; end case; end process;
end mp;
