MC33288 have similar function as MC33487 which is already EOL.
Solid state relay is relay, do not have "delay" function as mch173 said.
Flasher means it can switch on and off a relatively large current, such as the direction light. If they don't use it, it just fine, it can be a high side driver only. |
