gz16的定时器问题,为何无法进中断
gz16的定时器问题,为何无法进中断
我的程序是使用Timer 1的1通道为输出比较,0通道为输入捕捉。我现在并没有接通0通道,所以不存在输入捕捉的事情。
我在调试的时候,却不能进入输出比较中断,请问为什么?(主函数已经开中断,并且不使能COP)
急盼大家指教。
部分函数如下:
主函数:
void main(void)
{ EnableInterrupt;
  Init_Timer();
  for(;;)
初始化Timer定时器,使用TIM1CH1为输出比较,设定初值为OutCampareValue = 7813
void Init_Timer(void)
  unsigned char a;
  a = T1SC;
  T1SC = 0x26;  //set TSTOP and TRST simultaneously,let the counter stop at 0x00;
   T1SC1 = 0x54;
  T1SC0 = 0x48;
  T1MOD = 65535;
  T1SC_TSTOP = 0;
  T1CH1 = T1CNT + OutCampareValue;
中断服务程序
void interrupt INT_TIM1CH1OuputCompare(void)
  unsigned char a;//be used to read the T1SC1
  unsigned char i;//be used to mark the number of transmited bytes
  __asm sei; //关中断
 T1CH1 = T1CNT + OutCampareValue;//reload the T1CH1
  HPulse = PulseNum /100;
  Speed = (unsigned char)(HPulse * MeterPerHPulse * 2 *3.6); //   km/h
  Mileage = Mileage + HPulse * MeterPerHPulse / 1000;
  PulseNum = 0;
  T_data[0] = 0;  //load the data to be transmited
  T_data[1] = Speed;
  T_data[2] = (unsigned char)(Mileage / 65536 / 256);
  T_data[3] = (unsigned char)(Mileage / 65536 % 256);
  T_data[4] = (unsigned char)(Mileage % 65536 / 256);
  T_data[5] = (unsigned char)(Mileage % 65536 % 256);
  T_data[6] = (T_data[0] + T_data[1] + T_data[2] + T_data[3] + T_data[4] + T_data[5]);
  for( i = 0;i<7;i++)
    SCI_Transmit(T_data);
  a = T1SC1;
  T1SC1_CH1F = 0; //   Clear CH1F interrupt flag (the 7th bit)
  //TransmitId = TRUE;
 wuguang++;
 __asm cli; //开中断
在prm文件中,定义中断入口地址。
//VECTOR    3    INT_TIM1CH0InputCapture
VECTOR    4    INT_TIM1CH1OuputCompare
//VECTOR    15   KBI_Int
为什么没人回答呀
到freescale上去问
Freescale ic 全线代理(原摩托罗拉) 弘忆国际 Product Marketing:Sifachen(陈兴华) http://www.freescale.com.cn (飞思卡尔) Tel:0755-33388219 FAX:755-33388206、33388207 Mobile:13723451581 MSN:haihuaxing@hotmail.com ADD:深圳市罗湖
