下载时出错,各位帮看看
下载时出错,各位帮看看
使用IMPACT往XC2S200里配置BIT文件时出错。是并口/JTAG线
CB_PROGRESS_START - Starting Operation.
Connecting to cable (USB Port).
Cable connection failed.
Connecting to cable (Parallel Port - LPT1).
Checking cable driver.
 Driver windrvr6.sys version = 6.0.3.0.
 LPT base address = 0378h.
 ECP base address = 0778h.
Cable connection established.
CB_PROGRESS_END - End Operation.
Elapsed time =      1 sec.
// *** BATCH CMD : Identify
Identifying chain contents ....
'1': : Manufacturer's ID =Unknown
INFO:iMPACT:501 - '1': Added Device UNKNOWN successfully.
oldtext=Executing command...
GUI --- ************* Process Interrupted by User *************
ERROR:iMPACT:585 - A problem may exist in the hardware configuration.
 Check that the cable, scan chain, and power connections are intact,
 that the specified scan chain configuration matches the actual hardware, and
  that the power supply is adequate and delivering the correct voltage.
Validating chain...
INFO:iMPACT:1205 - Testing for '1' at position 4. The Instruction capture of the device 1 does not match expected capture.
INFO:iMPACT:1206 - Instruction Capture = '00000'
INFO:iMPACT:1207 - Expected    Capture = 'XXX01'
ERROR:iMPACT:1208 - '1':Boundary-scan chain test failed at bit position '1' .
我买的板子,他们说是出货前经过调试的,但我怎么弄都下载不了
用CHAIN DEBUG收到的TDO都是0
大虾们帮分析一下吧,谢谢了!!
bit文件还没有开始下载,也就是说在初始化的时候就已经出错了,软件没有认出你的芯片;
ERROR:iMPACT:585 - A problem may exist in the hardware configuration. Check that the cable, scan chain, and power connections are intact, that the specified scan chain configuration matches the actual hardware, and that the power supply is adequate and delivering the correct voltage.
如果你能排除以上错误提示中的内容,那么就只有换个芯片试试看了;
美梦成真-->噩梦降临!
