Error: VHDL Use Clause error at cfg_regs.vhd(30): design library "work" does not contain primary unit "CFGSPACE_SET"
Error: VHDL error at cfg_regs.vhd(58): object "RESET" is used but not declared
这样的ERROR非常多,找到包含package CFGSPACE_SET is语句的VHD文件并设置为库可是还是不行……
PS:我做的是PCI IP CORE。用的是MaxLock(可能吧)的源代码,不知道有没有大侠做过? |
