vhdl的小程序编译通过,可在SYNTHESIS却有这个毛病!
LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; ENTITY FPGA IS PORT ( PCLK:IN STD_LOGIC; VSYNC:IN STD_LOGIC; HREF :IN STD_LOGIC; D:IN STD_LOGIC_VECTOR(9 DOWNTO 0); Y:OUT STD_LOGIC_VECTOR(9 DOWNTO 0) ); END FPGA; ARCHITECTURE GET_DATA OF FPGA IS BEGIN PROCESS(VSYNC) VARIABLE Q :INTEGER RANGE 0 TO 12396; BEGIN IF(VSYNC'EVENT AND VSYNC='0')THEN IF(PCLK'EVENT AND PCLK='1')THEN IF (Q = 12396)THEN IF (HREF'EVENT AND HREF='1')THEN Y<=D; Q:= 0; END IF; ELSE Q:=Q+1; END IF; END IF; END IF; END PROCESS; END GET_DATA;
THIS USE OF CLOCK EDGE SPECIFICATION NOT SUPORT IN RUTION FPGA LINE 17 IN FILE,请求帮助!谢谢
