我的是se 6.1b的,昨天用se 6.0的也是这样的情况 难到是没破解?我下的是破解版,有keygen生成license的 安装的时候是按下面的方式装的 1.Install, Select Full product instllation. When asked for security key, select no. When you see License Wizard dialog, select close because license wizard dont know our license's format. 2.Use our keygen to generate license.dat, copy it to c:\flexlm directory. 3.set enviroment string: LM_LICENSE_FILE = c:\flexlm\license.dat
