“Putting Analog on the Bus”是否意指对Analog Signal进行A/D转换?
“Putting Analog on the Bus”是否意指对Analog Signal进行A/D转换? |
Putting Analog on the bus" is a concept proposed by Xicor, which is our goal. Using XDCP, you can program the analog function block usign SPI, I2C system bus... which is "putting analog on the bus" |
